It is currently Mon Jul 07, 2025 2:26 pm
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
 23hp SD Build
Post Re: 23hp SD Build
the plans i just got in have the bottom shaft going completely throught the housings with 2 brass bushings and all the way to the front of the belt cover box with a bearing there that bolts down to the front. did u do this or just have the two brass bushings.
25 yamaha pushing a 1642 welded flat
20 hp go-devil longtail for hunting
Wed Oct 30, 2013 9:41 pm
Instead of the bronze bushings I used a lower bearing housing from back water. It is an extremely high quality piece with 3 bearings and 2 seals I've put 24 hrs on this setup and its just as smooth as the day installed and no leaks!
Tue Nov 05, 2013 3:47 pm
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Thu Nov 07, 2013 7:24 am
Thanks for the info.
Thu Nov 07, 2013 10:30 pm
hey is the builder still on, Im wanting to find info on that clutch setup
Mon Mar 30, 2015 5:37 am
I would like some info as well. Does anyone know what it takes to build a surface drive with reverse?
Sat Aug 29, 2015 4:33 pm
Tue Jan 05, 2016 11:38 pm
What parts did you use on your shaft. I really like the setup you have
Sat Jul 23, 2016 12:29 am
Users browsing this forum: No registered users and 20 guests
