It is currently Thu Jul 10, 2025 1:05 pm
Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
 Threaded prop stuck on shaft, how to remove???
Post Re: Threaded prop stuck on shaft, how to remove???
I've seen some bring the motor up on the compression stroke with a 6" chunk of 3/8 rope stuffed into the sparkplug hole to lock the engine, then engage clutch to eliminate shaft rotation and use a prop wrench made out of flat stock to take the prop off before.
Mon Feb 17, 2014 8:30 am
It is on a 15' Lowe aluminum jonboat, on the heavy side. With that worn prop that was on it I'd get about 4000 rpm wide open. So, should I replace with a new 10x8 or an 11x10?
Mon Feb 17, 2014 9:07 am
11x10
B. MacDonald
Mon Feb 17, 2014 9:10 am
B. MacDonald
Mon Feb 17, 2014 9:42 am
I'm late to the party since I see in your other thread you already got it loose.
I had to duct tape a piece 2X4 to an 8lb sledge hammer and have the wife hold the shaft with a 12" crescent and a 4' cheater pipe while I beat the hell out of the old prop.
Mon Feb 17, 2014 9:52 am
Mon Feb 17, 2014 10:04 am
I just seen your other post on the hunt for a prop. Personally I'd run a die nut down that thread first before getting a new prop, because if the threads are beyond repair you might as well go hex shaft. S/s threads are unforgiving
Quote:
We had a lot of hunters from down under. All a bunch of great guys that liked to drink, root, and shoot shit in the dark. My kind of people.
Mon Feb 17, 2014 1:36 pm
If you stick with threads, pull the prop off on a very frequent basis to keep fresh anti-seize on it. I have been doing mine on a "PM" basis with oil changes and the occasional "just because."
Mon Feb 17, 2014 2:05 pm
^^ X 2 Put a 11x10 on it.
Mon Feb 17, 2014 6:22 pm
Users browsing this forum: No registered users and 40 guests
