It is currently Mon Sep 22, 2025 4:37 pm
Reply to topic  [ 12 posts ]
 GTR 35 RPM's at Full Throttle
Post GTR 35 RPM's at Full Throttle
Just purchased an GTR 35 on a center counsel 18' gator tail boat. I'm only turning 3550 on top end by myself, in deep water. Was wondering what is the recommended rpm at full throttle. also, what should the rpm's be in neutual when trottled down? The boat is mainly use in deep water, so any help on props would be appreciated. On top end, in deep water, with light load, i'm running about 25 mph.
Sun Jun 20, 2010 9:36 pm
Post Re: GTR 35 RPM's at Full Throttle
Welcome to MMT...
I'm sure the guys that sold her to you can give ya the best help - but - there
are three holes you can pin that thing into and it may run better if you experiment
with the other settings...
My stock 35 idles at about 850 and wide open 3800 to 3900 rpm in the water...
You can check your rev limiter by slowly reving it out of water on the trailer
to see what the max rpms are, a stock motor should be between 4000 and 4200..
Eat - Sleep - Hunt ! ! !
Sun Jun 20, 2010 9:57 pm
MMT Moderator
set governor to 4250 out of water rpm
what hole are you running motor in? Deep water keep it in the top hole
GTB 1860 w/ 2019 GTR40XD-HO
Sun Jun 20, 2010 9:59 pm
35 GTR with marshmellow on 1854 Gator Tail Boat.
Mon Jun 21, 2010 8:23 am
MMT Moderator
The other two holes allow you to trim down further if you were to be in pure mud and needed to trim fully down in order to get out of somewhere... With that being said I can trim down plenty being in the top hole so don't think your sacrificing anything here... Should you get in a bind just remove the nut & bolt and the motor will drop to the lowest hole where the pin should stay all the time.... You only have one bolt & nut to really move around.
I run now with my motor in the top hole.
Mon Jun 21, 2010 9:00 am
I will check what hole i'm running in and the rpm on the trailer when i get home today. I checked the plugs and air filter last night and they look fine. I know one of my problems is the motor is not alway throttling down in neutuel, causing me to have to engage forward at high rpm. Sometimes as high as 2000 rpm. Not good.
Mon Jun 21, 2010 9:31 am
MMT Moderator
Sounds like your springs might not be resetting. Check your idle your engine should always return back to an idle setting once you release the throttle if it doesn't there's something either causing it to stick or the springs are not putting enough force to reset the butterflies.
Mon Jun 21, 2010 9:56 am
Mon Jun 21, 2010 3:40 pm
rpm's are a little low...I was running 3800 wot when my motor was stock.
Mon Jun 21, 2010 7:38 pm
ran my motor when i got home and couldn't get it right. I can adjust the set screw and make it idle right but at wot it would only turn 3650. Then at wot i can turn the screw and make it turn 4250 but at idle it won't go under 2000 rpm. is this the springs?
Mon Jun 21, 2010 8:03 pm
i haven't messed with it yet but i just picked up my gtr35 the other day and i was running about 3600 in deep water wot
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Mon Jun 21, 2010 9:43 pm
MMT Moderator
Tue Jun 22, 2010 6:32 am
