It is currently Sat Nov 15, 2025 1:38 pm
Reply to topic  [ 6 posts ]
 prop for GTR 35
Post prop for GTR 35
picked up a 2007 GTR 35, had 89 hours on it, it was good shape except for the prop. worn down to 10 1/2 inches. I ordered the Tiger prop from Mud Buddy for it. After reading some of the other forum talk about which prop to go with. Was this a good choice.
Tue Aug 03, 2010 9:34 pm
Post Re: prop for GTR 35
Most of the GT guys would tell you to stick with the gt prop. Its the best all around prop for that motor. But the MB guys would tell you the same thing. I'm sure you'll be okay, its a good prop
Tue Aug 03, 2010 9:36 pm
GT prop is the best prop for a GT.
Tue Aug 03, 2010 9:38 pm
This is no chit I've tried them both brand new out of the box side by side on the same day and on a GT the GT prop was better.
Sat Aug 07, 2010 12:15 pm
MB designs der props for der motor and GT designs der props for der motors. The 2 motors have different reduction ratios and GT also designs der prop to have maximum effect in reverse while in da muck while MB does not have to consider reverse capabilities of a prop cause der reverse is a pushpole.
Sat Aug 07, 2010 12:25 pm
the MB prop really works great on my GTR 35. i will be getting pods in a couple of weeksand hopefully the 1752 all weld will run even better
Mon Aug 09, 2010 10:07 am
