It is currently Sat Jul 05, 2025 7:46 am
Reply to topic  [ 10 posts ]
 pd lower unit not holding grease
Post pd lower unit not holding grease
Hey Guys, is there supposed to be another plastic/teflon washer, sleeve or whatever down here? I have always had some grease ooze out a little, but this stuff has been washing out the fresh grease too recently. I could have swore there was a white colored plastic washer below this green one, or I have no clue why I thought so? I've put some pics below. Grease leak vs. cleaner view of sleeve/washer.
Also can somebody tell me what exactly holds my lower unit up in place when looking at the lower clutch coupler, there are 4 small bolts there under the clutch mounted into the lower plate, is that what holds the lower unit on?
Thanks in advance fellas!
Sat Sep 25, 2010 11:23 am
Post Re: pd lower unit not holding grease
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Sat Sep 25, 2010 11:24 am
Yes those 4 bolts hold the lower unit on. The new style uses 6 bolts.
Sat Sep 25, 2010 12:41 pm
18x48 Charles Leonard / 36PD
Sat Sep 25, 2010 12:44 pm
I bet that bitch turns good!
Sat Sep 25, 2010 8:10 pm
Sat Sep 25, 2010 8:32 pm
36hp pro-drive pushin a 1748 rick aucoin skiff
1500hp Mitsubishi pushing a 50' push boat
200merc pushing a 20' Mako
Sat Sep 25, 2010 9:48 pm
As stated over greased for sure.
2 shots every 25 hours is all you need.
Sat Sep 25, 2010 11:10 pm
yep, she does turn really easy! :lol:
In the past I didn't think I was remembering to grease it regular.
Guess I went ape $h!t on it. My transducer was putting a lot of spray on there, and prior to my nrw grease job it looked like some of the older grease had washed out and was real grey colored and runny.
Thanks again for the info! LR
Sun Sep 26, 2010 3:48 am
Keep pumping it to it!!It will help with it rusting :lol:
Sun Sep 26, 2010 3:14 pm
Users browsing this forum: No registered users and 65 guests
