It is currently Sun Jul 06, 2025 6:01 pm
Reply to topic  [ 12 posts ]
 How tight should she be???
Post How tight should she be???
Ok I burned up my stock prop on my 24 MB HD. I bought a "used" but not used prop that was a 11x10 "HEX". Turned out I needed a threaded prop. So I posted it up for what I had in it. Guy I sold it to is having a hard time getting it on. Said that he tried heating it up, banging it on and it is just is a tad to tight. Does anyone have any advise how to get her to fit? Is it "normal" for it to be tough to get on or should she slide right on? I had thought I had read that you can dremel the inside just a touch and feather down enough to fit. The guy I bought if from assured me it was a stock MB prop and would fit my motor, we just did not realize it was a threaded shaft. I hate to think that the guy can't use it and I will buy it back if needed. Just trying to figure out what the deal is before I sell it and the next guy has the same problem. Thanks, BC
Wed Oct 13, 2010 9:02 am
Post Re: How tight should she be???
let me get this right. its a hex prop you bought. then found out you needed a threaded prop. you sold the hex prop to a guy with a hex shaft, and it wont fit his hex shaft?
if so, the times ive pulled a hex prop they went on and off with out any problem.
Wed Oct 13, 2010 9:38 am
Wed Oct 13, 2010 9:48 am
could be he buggered up the shaft gittin his prop off or your prop has a spot in it thhat needs cleaned up.
Wed Oct 13, 2010 10:01 am
I'll pass that on to the guy or hope maybe he follows this thread. Regardless if he keeps it and makes it work or I buy it back, I will still need to make sure the next guy can use it. Thanks, BC
Wed Oct 13, 2010 10:13 am
Boat doc answered your question over on the other site. The newer shafts are a couple thousandths off the old ones. Just shave down the inside of the prop a lil and slide er on.
Wed Oct 13, 2010 10:15 am
Sounds like it was one of the older model props for sure. Thanks to everyone for the quick responses. I hate that the new owner has to modify but am relieved it is the right prop. BC
Wed Oct 13, 2010 10:25 am
I has to just take a file and shave sown a little on my new 3 blade. I have the hex shaft and noticed the same thing it seemed to be going on tigther than what I thought it should just shaved a little off and wallla went right on
Wed Oct 13, 2010 10:39 am
NeverMind... I thought this was about something else..
Wed Oct 13, 2010 10:42 am
Wed Oct 13, 2010 10:47 am
Wed Oct 13, 2010 11:02 am
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Wed Oct 13, 2010 1:07 pm
Users browsing this forum: No registered users and 70 guests
