It is currently Wed Sep 24, 2025 8:15 am
Reply to topic  [ 3 posts ]
 Changing 36 PD lower unit oil.
Post Changing 36 PD lower unit oil.
Ok, I'm fixing to change the lower unit oil on my 36 pd. How much oil does it take? Also which of the big allen heads at the top is the fill line?
Mon Nov 01, 2010 12:08 pm
Post Re: Changing 36 PD lower unit oil.
Oil:
Change after initial 8-10 hrs and then every 25-50 or annually.
Any quality 5W30 or 10W30 regular or synthetic (2 Quarts)
Oil Filter:
Briggs-492932S
WIX-51348
NAPA GOLD-1348
Spark Plugs:
Champion-RC14YC
NGK-ZFR5F-11
BOSCH-7527 or FR8 DC
gapped at .030
Fuel Filter:
BRIGGS-691035
WIX-33011
Fuel Line:
1/4" ID or 5/16" ID
Air Filter:
BRIGGS-692519
K&N-E-4665
Lower Unit Oil:
Change annually or every 100 hrs.
80-90 Weight Gear Oil
Grease:
Grease every 50 hrs. or annually
Marine Grade
Valve Clearance:
Check after first 50 hrs. and then every 250 hrs.
Valve clearance with valve springs installed and piston 1/4 in. past dead center (check when engine is cold)
Intake/Exhaust- 0.004 - 0.006 in.
Diagram A – Checking the Oil
(Every 25 Hours or once a month)
Step #1
Remove the top outer plug with 1/4” allen wrench. Oil should flow
out or you should be able to see it. Top off if needed
Replace the plug using teflon tape. Do not over tighten.Unit Maintenance
• Lower unit oil should be checked every 25 hours or once a month. Use only
SAE 80W-90 gear lubricant API service GL-5 (A synthetic gear oil such as
Royal Purple may be used.)
• Lower unit oil should be replaced once a year or every 50 hours. (See
diagram #B)
Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Mon Nov 01, 2010 5:00 pm
http://www.prodriveoutboards.com/images ... nual08.pdf
:roll: :roll: :roll:
Mon Nov 01, 2010 5:01 pm
