Prodrive guys and clutch
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=13546
Author:  sedlmayrje1723 [ Thu Nov 04, 2010 6:49 pm ]
Post subject:  Prodrive guys and clutch
Have any of you seen this?
Had a problem with the pto constant drive switch and then it just went out one day. The momentary button still worked until today. I just put a bungi cord around it to get by. That went out. I orderd a new switch already should have it tomorrow, but have any of you seen this issue. I have traced and wiggled wires and what not and I do not see any issues with them.
Author:  naj [ Thu Nov 04, 2010 7:31 pm ]
Post subject:  Re: Prodrive guys and clutch
If both switches arent working it might be the clutch.
Author:  sedlmayrje1723 [ Thu Nov 04, 2010 8:07 pm ]
The clutch was working before, the constand pull out switch wouldn't work, but the momentary would. I do not think it is the clutch. Anyone have issues with their switch.
Author:  Joe M [ Thu Nov 04, 2010 8:38 pm ]
Author:  naj [ Thu Nov 04, 2010 9:10 pm ]
Author:  sedlmayrje1723 [ Fri Nov 05, 2010 7:07 am ]
Joe M,
What was wrong with the wires going into the clutch? My wiring harness wires have wiggled lose, but I have never noticed anything with the clutch I guess. What should I look for.
Author:  sedlmayrje1723 [ Fri Nov 05, 2010 7:08 am ]
naj, What did you do to fix this problem that you had?
Author:  naj [ Fri Nov 05, 2010 7:35 am ]
Author:  sedlmayrje1723 [ Fri Nov 05, 2010 9:42 am ]
What should I look for and how should I investigate it? I want to be able to solve this issue very quickly.
Author:  Joe M [ Fri Nov 05, 2010 10:06 am ]
Inspect the wires that go into the clutch very close, right at the point where they go into it. Thats where my problem originated.
Author:  sedlmayrje1723 [ Mon Nov 08, 2010 5:54 pm ]
After 30 minutes on the phone with brian from prodrive we think we found the issue of needing a new clutch like you guys had said. Somewhere from the two wire plug to where it goes into the clutch there is a short. Has to be because that wire is getting hot as f$ck
Author:  naj [ Mon Nov 08, 2010 6:41 pm ]
Clutch is shorted out. I bet when its taken apart its outer plastic protective covering is melted and wires are broken.
Author:  J Wales [ Tue Nov 09, 2010 9:36 am ]
go ahead and replace the switch too...when the clutch shorted out, it probably fried the switch.
Author:  sedlmayrje1723 [ Tue Nov 09, 2010 11:15 pm ]
Thanks, they already told me both were coming out to me.
Author:  stumpjumer [ Tue Nov 16, 2010 11:44 am ]
let me ask you guys a question how many hours did you have on your engine when your clutch went out? i am having to replace mine too on my 2007 prodrive thats got 50 hours on it...
Author:  cbrown [ Tue Nov 16, 2010 1:48 pm ]
I have a 09 36 and the clutch went out around 50hrs. PD covered me for the new clutch and haven't had any problems with it after 30 hrs.
Author:  naj [ Tue Nov 16, 2010 5:38 pm ]
Author:  sedlmayrje1723 [ Tue Nov 16, 2010 5:56 pm ]
Author:  DUCKSBANE [ Tue Nov 16, 2010 7:56 pm ]
I got 50 on my first one which was replaced by PD. My second has 250 on it and no trouble.
Author:  coastal [ Wed Nov 17, 2010 9:23 am ]
Had one go out on my 08 PD with 20 something hours.Now have 140 on the new one.
