It is currently Mon Sep 22, 2025 7:29 pm
Reply to topic  [ 20 posts ]
 Prodrive guys and clutch
Post Prodrive guys and clutch
Have any of you seen this?
Had a problem with the pto constant drive switch and then it just went out one day. The momentary button still worked until today. I just put a bungi cord around it to get by. That went out. I orderd a new switch already should have it tomorrow, but have any of you seen this issue. I have traced and wiggled wires and what not and I do not see any issues with them.
Thu Nov 04, 2010 6:49 pm
Post Re: Prodrive guys and clutch
If both switches arent working it might be the clutch.
Thu Nov 04, 2010 7:31 pm
The clutch was working before, the constand pull out switch wouldn't work, but the momentary would. I do not think it is the clutch. Anyone have issues with their switch.
Thu Nov 04, 2010 8:07 pm
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Thu Nov 04, 2010 8:38 pm
Thu Nov 04, 2010 9:10 pm
Joe M,
What was wrong with the wires going into the clutch? My wiring harness wires have wiggled lose, but I have never noticed anything with the clutch I guess. What should I look for.
Fri Nov 05, 2010 7:07 am
naj, What did you do to fix this problem that you had?
Fri Nov 05, 2010 7:08 am
Fri Nov 05, 2010 7:35 am
What should I look for and how should I investigate it? I want to be able to solve this issue very quickly.
Fri Nov 05, 2010 9:42 am
Inspect the wires that go into the clutch very close, right at the point where they go into it. Thats where my problem originated.
Fri Nov 05, 2010 10:06 am
After 30 minutes on the phone with brian from prodrive we think we found the issue of needing a new clutch like you guys had said. Somewhere from the two wire plug to where it goes into the clutch there is a short. Has to be because that wire is getting hot as f$ck
Mon Nov 08, 2010 5:54 pm
Clutch is shorted out. I bet when its taken apart its outer plastic protective covering is melted and wires are broken.
Mon Nov 08, 2010 6:41 pm
go ahead and replace the switch too...when the clutch shorted out, it probably fried the switch.
1848 Brother w/ 36 PD
Tue Nov 09, 2010 9:36 am
Thanks, they already told me both were coming out to me.
Tue Nov 09, 2010 11:15 pm
let me ask you guys a question how many hours did you have on your engine when your clutch went out? i am having to replace mine too on my 2007 prodrive thats got 50 hours on it...
Tue Nov 16, 2010 11:44 am
I have a 09 36 and the clutch went out around 50hrs. PD covered me for the new clutch and haven't had any problems with it after 30 hrs.
09 1848 PD X-Series/ 36 PD
Tue Nov 16, 2010 1:48 pm
Tue Nov 16, 2010 5:38 pm
Tue Nov 16, 2010 5:56 pm
I got 50 on my first one which was replaced by PD. My second has 250 on it and no trouble.
1860 Phowler Extreme W/ stage 1 36 PD
Tue Nov 16, 2010 7:56 pm
Had one go out on my 08 PD with 20 something hours.Now have 140 on the new one.
Wed Nov 17, 2010 9:23 am
