2 blade 0r 3 blade prop for 36 pro drive http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=13999 |
Author: | comeonbaby [ Wed Nov 24, 2010 12:03 pm ] |
Post subject: | 2 blade 0r 3 blade prop for 36 pro drive |
Which does everyone run and why? What type of water and grass are you running? Also what type of speeds? I have a 18 x 48 with 36. What do ya'll run? |
Author: | JIMMY W [ Wed Nov 24, 2010 12:46 pm ] |
Post subject: | Re: 2 blade 0r 3 blade prop for 36 pro drive |
When I was running the prodrives the Hopkin's 2 blade prop's were the fastest!!You will run between 25-28 with that rig unloaded if I had to guess!!Just a guess! |
Author: | Phil_R [ Wed Nov 24, 2010 1:01 pm ] |
Stock 2-blade, 1854 cc: On step at 2900 ~ 3000 RPM with 500 lbs. or 1000 plus lbs., doesn't seem to matter. Run Suwannee and Wacissa rivers, more sand bottom than mud, lilly pads, stumps, logs, and rock. Long as she gets on step loaded heavy, I'm not really concerned about top speed, usually run 3300 ~ 3600 RPM depending on river conditions. |
Author: | T-Jacques [ Wed Nov 24, 2010 2:13 pm ] |
Hopkins 2 blade will be a 1 blade after a few hours run time ![]() |
Author: | JIMMY W [ Wed Nov 24, 2010 5:23 pm ] |
