Nickel Plating Prop? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=14344 |
Author: | tsutxn09 [ Mon Dec 06, 2010 8:28 pm ] |
Post subject: | Nickel Plating Prop? |
I have a guy that can nickel plate my prop for free and was wondering what you guys thought? Would it help with wear issues? |
Author: | Brown Duck [ Tue Dec 07, 2010 3:45 pm ] |
Post subject: | Re: Nickel Plating Prop? |
i work in the inspection business man and deal with all kinda metals and i would have to say i dont think nickel will help with your wear issues it is a really soft metal man. |
Author: | tsutxn09 [ Tue Dec 07, 2010 10:30 pm ] |
thanks for the insight man, i didnt know bc my buddy's dad works for a company that nickel plates all kind of stuff to make it last longer so i didnt know. |
Author: | UNCLE-J [ Tue Dec 07, 2010 10:34 pm ] |
The Nickel will make it last longer in weather, and normal wear and tear.. But, it wont help when you are running threw Sand.. Just picture a sandblasting machine hitting your prop.. |
Author: | tsutxn09 [ Wed Dec 08, 2010 8:41 am ] |
Thanks J, thats kind of what i was thinking but it doesnt hurt to ask some people more knowledgeable than I |
Author: | UNCLE-J [ Wed Dec 08, 2010 8:53 am ] |
Author: | North LA Hunter [ Wed Dec 08, 2010 5:44 pm ] |
What about putting a bead of tungsten on the edge of the prop? Thats some hard crap. |
Author: | meterman3 [ Wed Dec 08, 2010 9:20 pm ] |
i have a co in dallas that i am talking to that can boron difuse the prop it will go about .05 in the metal all of it it is packed in a box of the stuff and heated and controled cooling trying to find out the temper of the sst so we can fig out a heat up and cool down rate its not cheap not bad either if this works boys hang on to yer hats i have done this on slurry <sand and water mixed > control valves with NO WEAR will get back with yall this is a areospace prosses but does any 1 know the hardness of the props <rockwell> ? thanks mac |
Author: | tsutxn09 [ Wed Dec 08, 2010 9:54 pm ] |
That sounds like some cool stuff wonder what the costs might be |
Author: | meterman3 [ Wed Dec 08, 2010 10:06 pm ] |
got to get the hardness down will use yer prop all surfaces will be covered no tolance will change |
Author: | muddawgchuck [ Wed Dec 08, 2010 10:43 pm ] |
Never thought about that before but we have 3 huge slurry pumps i will see if i cant find the file on the and see what the impellars are made of. |
Author: | meterman3 [ Thu Dec 09, 2010 8:57 pm ] |
the great thing of this stuff is that you can buy a new prop get the boron baked in it goese about .05 in the metal but does not add any thing to the tolorances do not know about the impact on it but you can not scratch it with a file at all |
Author: | tsutxn09 [ Thu Dec 09, 2010 9:30 pm ] |
How does it hold up to sandblasting? |
Author: | meterman3 [ Fri Dec 10, 2010 8:26 am ] |
the high dollar inserts are made with it |
Author: | 50fps [ Sun Dec 12, 2010 8:35 am ] |
The rockwell will vary between 36 and 48 depending on manufacturer. |
Author: | HUNT4DEER [ Sun Dec 12, 2010 3:51 pm ] |
this coating sounds very interesting. ive been told that the friction of the water and blades does cause heat. sounds funny as its in the water but that what ive heard. and this heat can be substanitial ? i would figure in the mud and sand etc. it would be more. if this is so, how would the coating and the metal its bonded to react to the very rapid heat and cooling ? maybe a prop guy on here could validate the heat of the spinning prop? |
Author: | meterman3 [ Sun Dec 12, 2010 5:42 pm ] |
should no hurt this stuff is on the space shuttle |
Author: | shallow water master [ Sun Dec 12, 2010 5:49 pm ] |
