carnage........ http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=15125 |
Author: | tchredneck [ Wed Jan 05, 2011 9:50 am ] |
Post subject: | carnage........ |
Well while in the process of killing ducks and catching sacalait my lower unit decided to split like brothers in the hood when da cops roll up. Anyways I was running back up the calumet when I notice I have gear oil spewing out from my shaft beneath my clutch. And upon further inspection this was found...... suspect is the upper bearing..and it was a new style lower unit....I guess im just a clear water pirate ![]() |
Author: | Josh [ Thu Jan 06, 2011 4:23 pm ] |
Post subject: | Re: carnage........ |
guess these were the pics Bubba posted on FB |
Author: | T-Bubba [ Thu Jan 06, 2011 7:11 pm ] |
yea thats the ones I posted |
Author: | deltaduckmaster [ Thu Jan 06, 2011 7:27 pm ] |
Sorry to see that their hunter!! Those gears and lower unit are pretty costly!! |
Author: | tchredneck [ Fri Jan 07, 2011 8:35 am ] |
Author: | BROOKS [ Fri Jan 07, 2011 9:36 am ] |
Author: | POKER1 [ Fri Jan 07, 2011 12:38 pm ] |
Hell, its all costly unless you get it free. |
Author: | deltaduckmaster [ Sat Jan 08, 2011 8:05 pm ] |
Author: | take'emgator [ Sat Jan 08, 2011 8:10 pm ] |
Oh thats right we do have a life time warranty, well shucks i forgot about that! ![]() |
Author: | Chico80x [ Tue Jan 11, 2011 9:57 am ] |
Pro Drives are nice but it seems like there are less things to go wrong with the drive systems on the other manufacturers than on a Pro Drive. Maybe I'm wrong but it sure does seem easier to replace a gear, belt, and some seals than the lower unit on a pro drive. |
Author: | XGEN-DUCKMAN [ Wed Jan 12, 2011 12:00 am ] |
Author: | tchredneck [ Tue Jan 18, 2011 3:45 pm ] |
you have to pay to play thats all. I will say it did get me back 5 miles from when I discovered the minature oil well. its still a hell of alot cheaper than running airboats |
Author: | deltaduckmaster [ Tue Jan 18, 2011 6:00 pm ] |
Author: | craig [ Tue Jan 18, 2011 6:24 pm ] |
Author: | Tenpoint [ Tue Jan 18, 2011 6:41 pm ] |
Author: | XGEN-DUCKMAN [ Wed Jan 19, 2011 12:10 am ] |
Author: | pooldoo73 [ Tue Jan 25, 2011 6:15 pm ] |
Is that the new lower unit that they started installing around September 2010? |
Author: | XGEN-DUCKMAN [ Thu Jan 27, 2011 1:43 am ] |
I picked mine up in 2009 and it has the new style lower unit........ |
Author: | POKER1 [ Thu Jan 27, 2011 11:24 am ] |
They came out in 2008. |
Author: | pooldoo73 [ Thu Jan 27, 2011 5:42 pm ] |
There is a "newer" lower unit that is being used now, as of August/September 2010. The gearcase is now sealed right at the prop shaft. The prop shaft housing is now filled with grease to fix the problem of water getting in through bad seals at the prop. |
Author: | cb5331 [ Thu Jan 27, 2011 5:49 pm ] |
Same one Poker is talking about as far as I know...We def got one well before August 2010. *edit* Well, maybe you are talking about something different. I didn't thoroughly read that post the first time. So there is a grease zerk on the bottom now too, not just at the top or what? |
Author: | saveontaxes [ Thu Jan 27, 2011 5:51 pm ] |
I am sure that must be a free upgrade right? |
Author: | cb5331 [ Thu Jan 27, 2011 5:53 pm ] |
Author: | saveontaxes [ Thu Jan 27, 2011 6:03 pm ] |
yea, I guess they call that product improvement, but when it's a mb it's "they fuked me". ![]() |
Author: | cb5331 [ Thu Jan 27, 2011 6:08 pm ] |
Author: | saveontaxes [ Thu Jan 27, 2011 6:12 pm ] |
2 please ![]() ![]() |
Author: | cb5331 [ Thu Jan 27, 2011 6:15 pm ] |
Author: | saveontaxes [ Thu Jan 27, 2011 6:31 pm ] |
I'm not, but I'm gona get one off an outboard and put on, cuz it WILL go out. I looked at a cmc, but gt uses them and it don't seem to be worth a fuk either. So go with tried and true merc or I will just get a hyd cyl and pump and do it right. I do understand that putting 1/5 of the price of the mm for the trim is alot, so they ALL have to scrimp someware. |
Author: | meterman3 [ Thu Jan 27, 2011 9:03 pm ] |
just go mine new pd same lower new style but kp has added a grease pocket with a fitting, to have a grease seal in front off the gear oil |
Author: | pooldoo73 [ Fri Jan 28, 2011 12:47 pm ] |
Meterman3 may have explained it a little better. Maybe not. |
Author: | forever draggin [ Sat Mar 19, 2011 9:21 pm ] |
If my belt brakes I'm smart enough to cut my dock rope and limp n |
