Lower Unit http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=16564 |
Author: | spillwaysportsman [ Wed Mar 02, 2011 5:21 pm ] |
Post subject: | Lower Unit |
I have a 35 GTR and noticed a metal to metal noise in my lower unit. I checked my lower unit grease and there was barely any grease. I changed it about 15 hours previous. Since then, i have noticed a spot where the lower unit has a spot that grease is coming out. I assume that this is a bad seal? So i have been putting grease in it before very run. Has anyone has this problem? Is it urgent to fix? And should I replace it before I run again? THANKS! |
Author: | craig [ Wed Mar 02, 2011 6:31 pm ] |
Post subject: | Re: Lower Unit |
If grease is coming out of either end of the lower unit (prop end or bell housing end) it needs to have the seals replaced. If you're hearing grinding noise i would definately not use it until you have the issue resolved. Bring it to GT...It only takes 10 mins. to do the job. |
