It is currently Tue Sep 23, 2025 1:47 pm
Reply to topic  [ 13 posts ]
 Grease?
Post Grease?
Sorry newbie to all this i am sure its on here but could not find it in a pinch ...when greasen the lower end of my GTR's how much ya put in there? Is there seals that ya can blow out or do ya just fill till it comes out some where? ?
Sat Mar 26, 2011 9:35 pm
Post Re: Grease?
WestEndAngler has a video on that and other topics, about 5:10 into it you'll find what your looking for my boy! Its pretty simple, I mean if he can do it anyone can! lol
http://www.youtube.com/watch?v=797shKBeqC4
Sun Mar 27, 2011 12:25 am
Post Re: Grease?
Remove the bleed screw by the prop, then pump grease in at the insert bythe belt housing. Purge grease until all old grease is out, you will see a change in color (it will take allmost an entire tube of grease). Then replace bleed screw (do not add grease with bleed screw in place, this will blow your seals out).
Sun Mar 27, 2011 3:13 am
Post Re: Grease?
Thanks for the info. I ordered a GatorTail boat and motor last week. Posts like these answer questions I would be asking later...
1754 Gatortail Extreme / 35 GTR
Sun Mar 27, 2011 3:28 pm
Post Re: Grease?
Thanks!! ok know how often should ya do it ?? i have ran them about 5 hours close to 100 miles from the last time it was changed pulled that bleeder and that shit look brand new ??
Tue Mar 29, 2011 12:27 pm
Post Re: Grease?
I wanna say every 15 hrs.
Tue Mar 29, 2011 12:59 pm
Post Re: Grease?
Tue Mar 29, 2011 2:16 pm
Post Re: Grease?
Tue Mar 29, 2011 3:45 pm
Post Re: Grease?
Every 15 I check mine too. Just give it a couple pumps to make sure there is no water in there. Ive never completely flushed it.
Tue Mar 29, 2011 3:58 pm
Post Re: Grease?
Sweet thanks guys!!
Tue Mar 29, 2011 4:02 pm
Post Re: Grease?
I change mine every time I change my oil. I get some water out of mine but not much.
Mon May 16, 2011 6:50 pm
Post Re: Grease?
Tue May 17, 2011 6:02 am
Post Re: Grease?
Even if you get alittle water go ahead and change them, i mean they could completely go out while underway and you won't know and you may damage internals before you catch it
Tue May 17, 2011 6:25 am
