It is currently Tue Sep 23, 2025 12:04 am
Reply to topic  [ 11 posts ]
 Lower seal replacement???
Post Lower seal replacement???
Im still having trouble getiing the gear off to get to the seal i need to replace i read what i could find in the search section but i think im missing somthing. I got the 2 allen head screws out but now im stumped as to how the gear slides off so I can get to the seal. Thanks Oh yeah I have a 08 mb35
Sun Mar 27, 2011 1:00 pm
Post Re: Lower seal replacement???
With the 2 allen heads bolts out, hit the gear with a either a rubber mallet or use a block of wood with a hammer. The gear should fall off of the cone toward the seal, allowing you to remove the cone from the shaft, followed by the gear.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 27, 2011 3:24 pm
Thanks Camo. Got The gear off but it seems like the key was rusted on the taper lock and the shaft and when i went to slowy open it up to remove it. It cracked I eventully had to just split it in half and even after that the one half was completly stuck on the shaft with the key way. i finally got iy off removed the spacer and set spring and got to the seal. Guess I'll have more parts on the way now. LOl
Sun Mar 27, 2011 5:54 pm
:lol: Look on the bright side, ya broke yours now instead of when ya went to reassemble it, like I did. :x I did find out that 2 things from it, (1) the part isn't expensive, (2) you can actually still use it with it broken in 2 pieces.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 27, 2011 7:25 pm
lol thanks. had the motor apart anyway to put the new cam in and that s not here yet so hopfully after i get the new seals ordered all the parts should be hear. so does the seal just lay back in their and reverse the rest of the proccess. do i put the gear and all that together then slide it over the key way??
Sun Mar 27, 2011 9:26 pm
Man, it's been awhile since I've done one, but seems like the seal is behind a snap ring. Gear goes on 1st, then cone & keyway together.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 28, 2011 12:34 am
I got the snap ring out and the seal. So I put the gear on the shaft first then slid the cone on and just use the 2 allen screws to tighten it all toghether right. Thanks again for the help.
Mon Mar 28, 2011 5:08 am
I'm assuming you've got the keyway in there also, so yeah that's it.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 28, 2011 11:14 am
so apperntly i didnt get the seal out . i tried to press it out with just keeping the grease plug in and forcing it out but the seal is to blown. what i thought was the seal was just part of the rubber from the actual seal. so now whats the best and easiest way to get that out . i would like to not have to pull the whole shaft. let me know what ya thinkl
Mon Mar 28, 2011 1:21 pm
ok nevrmind that last post my buddy has a machine shop and he had a sela puller on hand got the whole seal ou this time . will post up when i get cam, timing key and seals put back toghether. thanks for the help camo.
Mon Mar 28, 2011 1:30 pm
Glad I could help. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 28, 2011 1:38 pm
