It is currently Tue Sep 23, 2025 4:14 pm
Reply to topic  [ 17 posts ]
 Prop shaft grease exit screw stripped. Suggestion.
Post Prop shaft grease exit screw stripped. Suggestion.
Why a Phillips screw head for this I'll never know. But apparently when my son last filled the shaft with grease he tighten the screw so much it cannot be unscrewed without stripping the head. What would you do?
Sun Mar 27, 2011 8:03 pm
Post Re: Prop shaft grease exit screw stripped. Suggestion.
Depends on if I was drinking....if I were, I'd beat the crap out my son ensuring he didn't do it again. Then I'd get a flat head screw driver and a hammer, and removed the stripped Phillips head screw.
Sun Mar 27, 2011 8:09 pm
Craig has a very good point and solution.... And you sure do blame alot of shit on your son.... Im guessing he is not the sharpes tool in the shed, or you fuck up alot of stuff and blame it on your kid.... Which one would it be????
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Sun Mar 27, 2011 8:16 pm
Prolly what happened is it was screwed when it was cold and now that it's warmed up, the screw expanded and seized. Better explanation than my son's fault. He's actually brilliant, but has to put up with my bull.
Sun Mar 27, 2011 8:30 pm
get a pd we use allen heads lol
driving a gd in ur lake
and i aprove this message
Sun Mar 27, 2011 8:48 pm
Put it on ice and see if it comes loose. :roll:
Sun Mar 27, 2011 8:49 pm
Sun Mar 27, 2011 8:54 pm
Beat the flat head in to the screw, then turn it. Coonass easy-out...
Sun Mar 27, 2011 8:57 pm
When you get it out replace it with a allen head screw
Sun Mar 27, 2011 9:35 pm
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Sun Mar 27, 2011 9:53 pm
Left hand drill bit and an extractor.
Sun Mar 27, 2011 10:18 pm
Needle nosed vice grips & replace it with a allen head.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 28, 2011 3:58 pm
Did you try a hand impact? The kind that you hit with a hammer. Works great on the tight phillips screws on motorcycles.
Sat Apr 02, 2011 7:39 pm
If all else fails, Take a hacksaw are a dremel tool and make a slot to fit a flat head screw driver across the screw head. Then tap on it with the screw driver inserted and work it in and out (not just out). Also make sure you use the right size screw driver, you want it to fit the slot snuggly.
And replace it with a BUTTON head allen screw.
Sat Apr 02, 2011 7:52 pm
I gave up mud motors
Sat Apr 02, 2011 7:57 pm
Got it out. My what a difference the right sized Phillips screwdriver makes. Looked for a hexed headed screw to replace. You'll need a 10 sized 32 machine threaded 3/8 inch screw. Very hard to fine. 1/2 inch is too long. A small o-ring is needed as well or use the old one. Get assortment at autozone.
Sun Apr 03, 2011 5:07 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Apr 04, 2011 7:25 am
