What to use as sealant on lower unit
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=17360
Author:  spktrout [ Thu Mar 31, 2011 12:14 pm ]
Post subject:  What to use as sealant on lower unit
I recently changed the seals on the lower end of the shaft on a 2008 mudbuddy long tail (27 hp). The stainless screw in cap at the end of the shaft that holds the seals in place has an o-ring at the base of the threads. Mud buddy uses some fancy aircraft grade sealant to help creat a watertight seal when it is closed back up. Any opinions out there on what to use that you can find at a local auto store. It would need something that would not harden like glue- maybe engine gasket sealant? Do you even need to seal it or just tighten it down and not worry about it? Thanks
Author:  MaXXis85 [ Thu Mar 31, 2011 12:15 pm ]
Post subject:  Re: What to use as sealant on lower unit
I use a sealant called "The Right Stuff" from any auto parts store when I rebuild differentials. It is some good stuff. I'm sure it can be used just fine in that application.
Author:  spktrout [ Thu Mar 31, 2011 12:25 pm ]
Thanks for the info. I will look for some.
Author:  Machine [ Tue May 03, 2011 11:41 am ]
it is a gasket shellac. I think permatex is the one that has the "indian head" brand. I use one from loctite called aviation gasket sealant. it is very messy and has to wear off so be careful.
Author:  Sko [ Wed May 04, 2011 11:54 am ]
Super black
