It is currently Tue Sep 23, 2025 5:44 am
Reply to topic  [ 14 posts ]
 3/8" shaft longtail prop, does it exist?
Post 3/8" shaft longtail prop, does it exist?
I have a home made 5 hp long tail with a crummy plastic prop. It has a 3/8" shaft with a shear pin setup, held on with a nut. is there a metal long tail smaller diameter prop with this size shaft?
Just a displaced hillbilly in Cajunland
Beavertail Predator LT/17' alum vee total mismatch but ya use what ya gots
Wed Apr 27, 2011 10:51 pm
Post Re: 3/8" shaft longtail prop, does it exist?
Shear pin techknoledgy, B.M says it don't work.
Thu Apr 28, 2011 5:56 pm
It wouldn't be my first choice, but its all I got to work with for now. Anyone seen a metal prop similar to this or hell even a source for another plastic prop would do me. i just use this thing to putt from my backyard cooley to the bayou, doesn't get much abuse but does go where a outboard can't at low tide.
Thu Apr 28, 2011 9:14 pm
maybe try one from a trolling motor
Sat Apr 30, 2011 7:53 pm
http://www.youngprops.com/index.html
Sun May 01, 2011 9:17 am
Ditto on the sleeve job
Duckdon
Sun May 01, 2011 9:18 am
Thanks a lot guys, don't know why I didn't think of the sleeve option before? Thats why I always get a few extra pairs of eyes on a problem, always helps. Might even get lucky and find a prop for a direct fit from that link Thanks
Sun May 01, 2011 10:55 am
that appears to be a trolling motor prop. you may be able to get a new plastic one of if you look real hard u may find an alum. one. its going to be an older motor and ide check some marinas for some old stock. back in the day they would have a display with odd alum. props.
Sun May 01, 2011 3:54 pm
also if you go with the sleve thing ide ask around for a used or worn out prop to try first. ide say about a 10-12 hp worn out prop may work or it would give you an idea. any thing should work better than the plastic one you have. i would imagen it flexes pretty bad under load.
Sun May 01, 2011 3:58 pm
The plastic prop and shear pin is to protect that tiny shaft. The shaft will not last one good hit otherwise.
18'x54"CC Hanko/ 36PD
Sun May 01, 2011 10:20 pm
not being a smartass by anymeans but i dont think he will gain high enough speeds to get a "good hit" to mess up his shaft at all.
Tue May 03, 2011 7:46 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: yea this thing sure ain't like my old 15 whaler with a 115 inline 6 merc on it, but the damn thing is so stingy on fuel ya gotta love it. I bet I didn't use 2 cups of fuel this mornin when I went out to check my jug lines (bout a 1.5 mile trip), got me a 8lber, 3lber and a couple 1lbers.
Tue May 03, 2011 7:54 pm
i got an old (about) 5" ish aluminum prop with a shear pin in it if you want me to go find it for ya
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Tue May 03, 2011 9:38 pm
The Boat Yard has a lot of old junked motors that have aluminum props. I bet u could get a prop from there that u could work with.
Wed May 04, 2011 6:06 am
