3/8" shaft longtail prop, does it exist? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=18094 |
Author: | CaptCameltoe [ Wed Apr 27, 2011 10:51 pm ] |
Post subject: | 3/8" shaft longtail prop, does it exist? |
I have a home made 5 hp long tail with a crummy plastic prop. It has a 3/8" shaft with a shear pin setup, held on with a nut. is there a metal long tail smaller diameter prop with this size shaft? |
Author: | Woodiebuster [ Thu Apr 28, 2011 5:56 pm ] |
Post subject: | Re: 3/8" shaft longtail prop, does it exist? |
Shear pin techknoledgy, B.M says it don't work. |
Author: | CaptCameltoe [ Thu Apr 28, 2011 9:14 pm ] |
It wouldn't be my first choice, but its all I got to work with for now. Anyone seen a metal prop similar to this or hell even a source for another plastic prop would do me. i just use this thing to putt from my backyard cooley to the bayou, doesn't get much abuse but does go where a outboard can't at low tide. |
Author: | mudmarshall [ Sat Apr 30, 2011 7:53 pm ] |
maybe try one from a trolling motor |
Author: | 50fps [ Sun May 01, 2011 9:17 am ] |
http://www.youngprops.com/index.html |
Author: | Duckdon [ Sun May 01, 2011 9:18 am ] |
Ditto on the sleeve job Duckdon |
Author: | CaptCameltoe [ Sun May 01, 2011 10:55 am ] |
Thanks a lot guys, don't know why I didn't think of the sleeve option before? Thats why I always get a few extra pairs of eyes on a problem, always helps. Might even get lucky and find a prop for a direct fit from that link Thanks |
Author: | HUNT4DEER [ Sun May 01, 2011 3:54 pm ] |
that appears to be a trolling motor prop. you may be able to get a new plastic one of if you look real hard u may find an alum. one. its going to be an older motor and ide check some marinas for some old stock. back in the day they would have a display with odd alum. props. |
Author: | HUNT4DEER [ Sun May 01, 2011 3:58 pm ] |
also if you go with the sleve thing ide ask around for a used or worn out prop to try first. ide say about a 10-12 hp worn out prop may work or it would give you an idea. any thing should work better than the plastic one you have. i would imagen it flexes pretty bad under load. |
Author: | pooldoo73 [ Sun May 01, 2011 10:20 pm ] |
The plastic prop and shear pin is to protect that tiny shaft. The shaft will not last one good hit otherwise. |
Author: | jordy [ Tue May 03, 2011 7:46 pm ] |
not being a smartass by anymeans but i dont think he will gain high enough speeds to get a "good hit" to mess up his shaft at all. |
Author: | CaptCameltoe [ Tue May 03, 2011 7:54 pm ] |
Author: | LA Mudder [ Tue May 03, 2011 9:38 pm ] |
i got an old (about) 5" ish aluminum prop with a shear pin in it if you want me to go find it for ya |
Author: | pooldoo73 [ Wed May 04, 2011 6:06 am ] |
The Boat Yard has a lot of old junked motors that have aluminum props. I bet u could get a prop from there that u could work with. |
