It is currently Tue Sep 23, 2025 11:49 am
Reply to topic  [ 8 posts ]
 New jam nut - where / what kind?
Post New jam nut - where / what kind?
I had to split the jam nut to get the prop off of my 27 kohler long tail beavertail... Now I need to get a new one. Ace hardware was no help... Where can I get a new jam nut and what kind of material should it be to prevent rust, brass?
The 4 washers between the jam nut and the prop are also very thin and worn. Should I replace these with brass washers?
I have heard different opinions on slack in the prop when installed, can someone point me to, or list the correct install procedure... Thanks in advance.
Sat May 21, 2011 6:18 am
Post Re: New jam nut - where / what kind?
Put a brass lock nut on it, ask WEA where he got his
Sat May 21, 2011 6:35 am
I'd want to get it from the factory - cause they would likely have done
a little RnD getting it right....
The 2 trains of thought that I know of on a threaded shaft LT are...
Hand tighten the prop and retaining nut - using an anti-sieze compound
with brass washers on both sides of the prop....
Leave 1/4 turn of slack in prop to retaining nut - so that it will "free itself"
when in use...
But that sounds like heck right at first - so I always went with option 1 and
needed a torch and weapons to get the dang thing off 100 hours later - a
prop removal tool helps too - 50.00 at GD - or make your own weapons - LOL
Sat May 21, 2011 6:40 am
Sat May 21, 2011 6:44 am
I forgot he was talking about a GD prop nut, forgot that there was so much crap to getting GD's props off....lol Cutting new trails, i love cutting new trails that other people can't make it through
Sat May 21, 2011 6:49 am
Thought this may help in the future
viewtopic.php?f=6&t=13709&hilit=+Prop+removal
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat May 21, 2011 7:04 am
giga gd charges 50.00 for a wrench ? pd has a pretty slick alum for 24.00 i think
driving a gd in ur lake
and i aprove this message
Sat May 21, 2011 5:42 pm
He is running a Beavertail longtail. I owned one at one time. You will probably have to replace the bushings and the nut. Unless you can find any the same size, you will have to get some replacements from the factory. Get you some extra for maintenance.
As Giga stated, you do not have to tighten the nut any more than handtight. Actually the nut is more for thread protection on the shaft and nothing more. The prop will not just come off by itself.
Use some brass neverseize or Loctite marine when you put the prop back on.
Mon May 23, 2011 1:57 pm
