It is currently Tue Sep 23, 2025 4:00 pm
Reply to topic  [ 9 posts ]
 whats the proper way to measure the prop ?
Post whats the proper way to measure the prop ?
i got a 35 hp mb and just want to see if the prop is bad got the motor on a 1754 gt and im only getin 21.4mph with 3 ppl and just fishin gear
Sun May 29, 2011 3:02 pm
Post Re: whats the proper way to measure the prop ?
I was wondering the same thing when I saw your post. Does it still have all of the trailing edge cup, or has it wore down? I had worn mine off & lost 5 mph.
Sent from my Droid because I'm trying to be as cool as you someday.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun May 29, 2011 4:28 pm
On the LT you can just measure diameter...
But on the SD --- I find blade width is a better way to gauge wear, as
the wear at mid-blade robs you of speed and causes prop lift troubles
on a balanced design like my GDSD....
After 1/4" width is lost at mid-blade --- I consider my props "gone" and
replace with new --- rpms creep up 200 to 300 while speed goes down
4 to 8 mph --- a bit of re-cupping might put a lil extra run time on one....
Eat - Sleep - Hunt ! ! !
Sun May 29, 2011 4:39 pm
Sun May 29, 2011 6:36 pm
they are 3800 to 3900
Sun May 29, 2011 6:41 pm
I might have gained 100 rpm @ most, but I keep an eye on it anyhow since I don't run a rev box. I keep it under 4700 for the most part, but never let it over 4800.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun May 29, 2011 9:48 pm
I was just curious,thanks
Sun May 29, 2011 10:36 pm
anyone got a pic of the points thats i should be measureing from ?
thanks
Mon May 30, 2011 7:43 am
Mon May 30, 2011 7:49 am
