Grease ozzing from the drive shaft ??
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=18769
Author:  outdoorgod [ Tue May 24, 2011 10:44 am ]
Post subject:  Grease ozzing from the drive shaft ??
I have a little bit of what looks/feels like greese coming out from the drive shaft in the pictures below and was wondering if this is normal or a problem ??
it is from the join farthest from the prop or closeest to the belt drive.
Thanks,
Author:  BROOKS [ Tue May 24, 2011 2:00 pm ]
Post subject:  Re: Grease ozzing from the drive shaft ??
"DagGum It"
Thats what I calls them photos .....
Author:  keystone light [ Tue May 24, 2011 7:00 pm ]
Mine has what looks like transmission fluid leaking out of the grease zert. Trying to figure out what it is.
Author:  Team Camo [ Tue May 24, 2011 7:12 pm ]
Neff, yours is normal, it's just the thinner grease oozing from the heat.
ODG, your housing is cracked.
Author:  keystone light [ Tue May 24, 2011 7:47 pm ]
Makes since. Thanks camo.
Author:  dfou [ Wed May 25, 2011 7:06 pm ]
Can that be welded or does the whole thing need to be replaced?
Author:  Team Camo [ Wed May 25, 2011 7:14 pm ]
He also posted it on MB, & got more detailed answers. According to Andy (BoatDr) it has to be replaced. I initially thought the same about having it welded, until he said the only 2 options both included replacing it. It's actually 2 pieces pressed together & apparently he must've tried to repair one before, rather than replace it & it was a no-go.
Author:  saveontaxes [ Thu May 26, 2011 5:31 am ]
Author:  dfou [ Thu May 26, 2011 7:13 am ]
Author:  carlosd321 [ Sat May 28, 2011 5:48 pm ]
Where are you located and what do you have? Im trying to decide on getting a longer shaft for my 35, if i do I will be looking to get rid of my current one if you are interested and looking.
Author:  Salty Dawg [ Sat May 28, 2011 7:26 pm ]
Author:  outdoorgod [ Tue May 31, 2011 11:18 am ]
I pulled the drain plug on the shaft and released the excess grease which helped allot. I'm going to run it for a while and see if it keeps up. Team Camo was right and the thread on the MB forum is much more detailed. I hope this all works out without any substantial change required. I use JB Weld on everything !!
C-u on the water !!
