whats the proper way to measure the prop ?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=18900
Author:  duckmananderson [ Sun May 29, 2011 3:02 pm ]
Post subject:  whats the proper way to measure the prop ?
i got a 35 hp mb and just want to see if the prop is bad got the motor on a 1754 gt and im only getin 21.4mph with 3 ppl and just fishin gear
Author:  Team Camo [ Sun May 29, 2011 4:28 pm ]
Post subject:  Re: whats the proper way to measure the prop ?
I was wondering the same thing when I saw your post. Does it still have all of the trailing edge cup, or has it wore down? I had worn mine off & lost 5 mph.
Sent from my Droid because I'm trying to be as cool as you someday.
Author:  Gigafowl [ Sun May 29, 2011 4:39 pm ]
On the LT you can just measure diameter...
But on the SD --- I find blade width is a better way to gauge wear, as
the wear at mid-blade robs you of speed and causes prop lift troubles
on a balanced design like my GDSD....
After 1/4" width is lost at mid-blade --- I consider my props "gone" and
replace with new --- rpms creep up 200 to 300 while speed goes down
4 to 8 mph --- a bit of re-cupping might put a lil extra run time on one....
Author:  dog walker [ Sun May 29, 2011 6:36 pm ]
Author:  duckmananderson [ Sun May 29, 2011 6:41 pm ]
they are 3800 to 3900
Author:  Team Camo [ Sun May 29, 2011 9:48 pm ]
I might have gained 100 rpm @ most, but I keep an eye on it anyhow since I don't run a rev box. I keep it under 4700 for the most part, but never let it over 4800.
Author:  dog walker [ Sun May 29, 2011 10:36 pm ]
I was just curious,thanks
Author:  duckmananderson [ Mon May 30, 2011 7:43 am ]
anyone got a pic of the points thats i should be measureing from ?
thanks
Author:  Gigafowl [ Mon May 30, 2011 7:49 am ]
