It is currently Tue Sep 23, 2025 12:01 am
[ 8 posts ] |
lower gear change on a mudbuddy
richard nagon
whats involved in the changing of the lower gear. procudure or any special tools involved. thanks.
_________________ JUST ANOTHER FARMER ON WELFARE
Sun Jun 12, 2011 9:49 am |
Team Camo
 Re: lower gear change on a mudbuddy
Back out the 2 allen head bolts that hold the gear on the cone, run 1 of the bolts in the 3rd hole in the cone until it bottoms out, then get another 1/4-1/2 turn on it. That should push the gear off of the cone, if not, tap it with a hammer & turn the screw some more. Repeat until the gear slips off the back side of the cone toward the shaft housing. Next, take a wooden shim & slip it into the slit on the cone just enough to loosen it from the shaft. Remove cone & gear, replace everything back onto shaft.
Mon Jun 13, 2011 12:10 am |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
Be extra carefull when prying that cone off. I cracked mine the first time I did it. i have heard it will still work craked but I orderd a new one and replaced the seal in it right away just to be on the safe side. Like camo said use a wood dhim I found out a flat head screw driver was a little much. On the plus side it comes off way easier in 2 pieces
Mon Jun 13, 2011 8:33 am |
MaXXis85
They will work just fine with a cracked Taper lock bushing once they are aligned and pulled back into the pulley the friction bond will clamp to the shaft and to the the pulley.
Mon Jun 13, 2011 9:16 am |
Team Camo
Mon Jun 13, 2011 9:36 am |
MaXXis85
Mon Jun 13, 2011 10:40 am |
BoatDR
Mon Jun 13, 2011 7:23 pm |
richard nagon
thanks for the good info.
Wed Jun 15, 2011 6:36 pm |
[ 8 posts ] |
