lower gear change on a mudbuddy
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=19206
Author:  richard nagon [ Sun Jun 12, 2011 9:49 am ]
Post subject:  lower gear change on a mudbuddy
whats involved in the changing of the lower gear. procudure or any special tools involved. thanks.
Author:  Team Camo [ Mon Jun 13, 2011 12:10 am ]
Post subject:  Re: lower gear change on a mudbuddy
Back out the 2 allen head bolts that hold the gear on the cone, run 1 of the bolts in the 3rd hole in the cone until it bottoms out, then get another 1/4-1/2 turn on it. That should push the gear off of the cone, if not, tap it with a hammer & turn the screw some more. Repeat until the gear slips off the back side of the cone toward the shaft housing. Next, take a wooden shim & slip it into the slit on the cone just enough to loosen it from the shaft. Remove cone & gear, replace everything back onto shaft.
Sent from my Droid because I'm trying to be as cool as you someday.
Author:  fowl habbit [ Mon Jun 13, 2011 8:33 am ]
Be extra carefull when prying that cone off. I cracked mine the first time I did it. i have heard it will still work craked but I orderd a new one and replaced the seal in it right away just to be on the safe side. Like camo said use a wood dhim I found out a flat head screw driver was a little much. On the plus side it comes off way easier in 2 pieces
Author:  MaXXis85 [ Mon Jun 13, 2011 9:16 am ]
They will work just fine with a cracked Taper lock bushing once they are aligned and pulled back into the pulley the friction bond will clamp to the shaft and to the the pulley.
Author:  Team Camo [ Mon Jun 13, 2011 9:36 am ]
Author:  MaXXis85 [ Mon Jun 13, 2011 10:40 am ]
Author:  BoatDR [ Mon Jun 13, 2011 7:23 pm ]
Author:  richard nagon [ Wed Jun 15, 2011 6:36 pm ]
thanks for the good info.
