New Prodrive Grease Fitting http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=19344 |
Author: | Wilson [ Fri Jun 17, 2011 9:31 pm ] |
Post subject: | New Prodrive Grease Fitting |
I saw a Prodrive ad that showed a new zerk fitting on the lower unit that mine does not have. It must be something new on the 2011 models. It is on top of the LU facing up, right before where the cavitation plate meets the LU. Anyone know what it's for? |
Author: | KeNnY [ Sat Jun 18, 2011 5:51 am ] |
It greases the shaft that connects to prop |
Author: | POKER1 [ Sat Jun 18, 2011 9:34 am ] |
Post subject: | Re: New Prodrive Grease Fitting |
Just like the 08 addition of the upper grease bearing / seal, they added one to the lower bearing now. Trying to stop the seal leaks by the added grease pressure I guess . |
Author: | meterman3 [ Sat Jun 18, 2011 1:49 pm ] |
It's a grease seal between the hard seal like the gd And I drive a pd and approve this message |
Author: | pooldoo73 [ Sat Jun 18, 2011 2:09 pm ] |
The gear case is now sealed off from the prop shaft. The prop shaft housing is grease filled instead of oil filled so that when the lower prop shaft seals get bad it doesn't let water into the gearcase. They r new as of 09/2010. I got one of the first ones, by chance. |
Author: | POKER1 [ Sat Jun 18, 2011 5:54 pm ] |
Author: | bayouboy [ Sat Jun 18, 2011 10:17 pm ] |
Both the upper spline and lower prop shafts are now greased filled and the gears are still oil bath. No need for the vent on top either they come plugged now. I've been running one for a while and its the best thing since sliced bread imo. Just remove the bottom plug ( where you use to drain the gear oil) and pump grease until it comes out clean. So now if your prop seals go out it will just leak grease and not allow water get in the gear housing. |
Author: | pooldoo73 [ Sun Jun 19, 2011 2:59 pm ] |
Wut he said! |
Author: | POKER1 [ Sun Jun 19, 2011 3:01 pm ] |
Gotcha, just the shaft and not the whole LU. |
