It is currently Tue Sep 23, 2025 1:34 pm
[ 6 posts ] |
8x4 prop is to big for my 9hp. Question is?
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
I got an 8x4 prop for my 9hp lt and i cant get any rpms. Now i dont run mud and the prop has a heavy cup, question is if i remove the cup will this act as pitch removal or should i just work the diameter down or both to gain rpms?
Tue Jun 21, 2011 7:37 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: 8x4 prop is to big for my 9hp. Question is?
thats the sandard size prop for a 9 hp so u might have oher problems like dirty carb or govonor out of adjustment or throttle cable stretched!!!!!
Tue Jun 21, 2011 7:46 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
The 9hp briggs Vanguard we are building now is going to have a 7.5x4......
_________________ If I can't Break it, it can't be Broke.............................
Wed Jun 22, 2011 12:00 am |
garjacker
just built it. motor has 2 hours on it. on my 16hp i ran a backwater 9x6 and a gd 9x3 and they ran at about same rpm. the 9x3 has more cup. i dont know the maker of this prop but it is heavy made and more cup than my 9X3. does cup in a way = pitch? if i remove it how will it effect its performance?
Wed Jun 22, 2011 4:03 am |
pokey79
yes the cup on a prop stops the slip!!!! cup is like a tire with alot of rubber left vs. a bald tire!!!
Wed Jun 22, 2011 6:43 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
Removing cup from a LT prop can have bad results. The cup on gdlt keeps the prop n the water. As the cup wears off the prop will come out of the water when running open water.
_________________ 18'x54"CC Hanko/ 36PD
Wed Jun 22, 2011 2:03 pm |
[ 6 posts ] |
