It is currently Tue Sep 23, 2025 5:54 am
Reply to topic  [ 6 posts ]
 GoDevil hex prop shaft?
Post GoDevil hex prop shaft?
I'm asking this question without doing any searches. But is the mud buddy shaft with the hex end interchangeable with the GoDevil shaft. I have found I like the 2 blade prop from go devil best, but after 30-40 hours, I have to have the prop heated with a torch and then torqued off the threaded shaft by a machine shop.
The hex shaft and prop seems like a much easier setup to deal with.
Mon Aug 01, 2011 6:08 am
Post Re: GoDevil hex prop shaft?
IIRC, the Go-Devil shaft is 2 pieces with a CV joint in the middle and the Mud Buddy is 1 piece. Anything is possible, and I am sure you can make/have one made.
GTR, Waitin' on a DFOU hull
Mon Aug 01, 2011 2:11 pm
Mon Aug 01, 2011 2:22 pm
There is a will, so there is a way.
Go get some 7/8 cold rolled and have it hex'd and keywayed to fit your CV-joint and pulleys at a local machine shop.
My .02
Mon Aug 01, 2011 2:38 pm
Let me correct my original post. I find the MudBuddy Big Blade to be my best performer over the 2 or 3 blade from GD. I do run a big boat and I find the 2 blade has too much pitch.
I don't understand how all the GD surface drives are being shipped with 3 blades and MB has basically ditched their 3 blade design and went back to the 2 blade.
I also like that the Big Blade is $179 new.
Mon Aug 01, 2011 11:44 pm
OK - then best help I could offer is that prop removal tool that GD sells, with
a good bit of grease on the shaft at installation and the 2 brass washers installed
one behind the prop and one in front - I have had no problems swapping mine out....
The GD 2 blade is a Hopkins design and Hopkins can sell you one in your choice
of pitch - but they are more expensive.... PM me is you want his phone number....
Only heard of one prop mfg with a threaded hex adapter for their props - but it
is a non-standard size hex and never read any solid revues that were favorable
for a SD - Leading Edge BBlades - http://www.bblades.com/leadingedge/
Tue Aug 02, 2011 12:08 am
