GoDevil hex prop shaft?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=20524
Author:  bbb [ Mon Aug 01, 2011 6:08 am ]
Post subject:  GoDevil hex prop shaft?
I'm asking this question without doing any searches. But is the mud buddy shaft with the hex end interchangeable with the GoDevil shaft. I have found I like the 2 blade prop from go devil best, but after 30-40 hours, I have to have the prop heated with a torch and then torqued off the threaded shaft by a machine shop.
The hex shaft and prop seems like a much easier setup to deal with.
Author:  Richard in LA [ Mon Aug 01, 2011 2:11 pm ]
Post subject:  Re: GoDevil hex prop shaft?
IIRC, the Go-Devil shaft is 2 pieces with a CV joint in the middle and the Mud Buddy is 1 piece. Anything is possible, and I am sure you can make/have one made.
Author:  Gigafowl [ Mon Aug 01, 2011 2:22 pm ]
Author:  Woodiebuster [ Mon Aug 01, 2011 2:38 pm ]
There is a will, so there is a way.
Go get some 7/8 cold rolled and have it hex'd and keywayed to fit your CV-joint and pulleys at a local machine shop.
My .02
Author:  bbb [ Mon Aug 01, 2011 11:44 pm ]
Let me correct my original post. I find the MudBuddy Big Blade to be my best performer over the 2 or 3 blade from GD. I do run a big boat and I find the 2 blade has too much pitch.
I don't understand how all the GD surface drives are being shipped with 3 blades and MB has basically ditched their 3 blade design and went back to the 2 blade.
I also like that the Big Blade is $179 new.
Author:  Gigafowl [ Tue Aug 02, 2011 12:08 am ]
OK - then best help I could offer is that prop removal tool that GD sells, with
a good bit of grease on the shaft at installation and the 2 brass washers installed
one behind the prop and one in front - I have had no problems swapping mine out....
The GD 2 blade is a Hopkins design and Hopkins can sell you one in your choice
of pitch - but they are more expensive.... PM me is you want his phone number....
Only heard of one prop mfg with a threaded hex adapter for their props - but it
is a non-standard size hex and never read any solid revues that were favorable
for a SD - Leading Edge BBlades - http://www.bblades.com/leadingedge/
