GTR Lower Unit Rear Seal http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=20940 |
Author: | wrd_sctt [ Fri Aug 12, 2011 7:11 am ] |
Post subject: | GTR Lower Unit Rear Seal |
d |
Author: | MaXXis85 [ Fri Aug 12, 2011 7:28 am ] |
Post subject: | Re: GTR Lower Unit Rear Seal |
Replace the seals and replace the screw. Here is a threads where i explained the process of rebuilding a GTR lower unit. viewtopic.php?f=3&t=20652 |
Author: | take'emgator [ Fri Aug 12, 2011 12:10 pm ] |
Yeah you need to get that screw out and get a new one for it, always remove screw to put more grease in or you'll blow a seal everytime.....Rear seal is very easy to change |
Author: | MaXXis85 [ Fri Aug 12, 2011 12:11 pm ] |
You mean SEALS Take'em |
Author: | deltaduckmaster [ Fri Aug 12, 2011 3:02 pm ] |
You do know that you have a backerd seal for that reason!! Instead of popping seals with grease cause people dont pull the screw out they designed it that way!! Get that stripped out screw out and you should be fine!! if it not leaking grease leave it alone !! |
Author: | wrd_sctt [ Fri Aug 12, 2011 6:05 pm ] |
Thank fellas........... |
Author: | pooldoo73 [ Sun Aug 14, 2011 7:27 am ] |
I wouldn't have thought the bottom seal was trashed after pushing grease out. I fill my PD lower shaft wif grease until it squeezes out of the seal, per KP. I would think GTR used the same type seals on their lower to make them idiot proof, kinda. |
Author: | wrd_sctt [ Sun Aug 14, 2011 8:21 am ] |
What tore the seal up is some wire I got wrapped up in the prop not from over pumping grease. I will be changing the seals as soon as I get in from work. Thanks for all ya'lls input. |
Author: | waterfowl1 [ Wed Sep 07, 2011 3:31 pm ] |
i agree. pull the screw when pumping grease in. otherwise you WILL blow the seals out. |
Author: | deltaduckmaster [ Wed Sep 07, 2011 4:08 pm ] |
Author: | CAJUN OUTLAW [ Wed Sep 07, 2011 4:17 pm ] |
if i remember correctly,the silver,round thingy that you gonna take off to get to the seals is backwerds threaded,but not sure on this. |
Author: | Robn1020 [ Wed Sep 07, 2011 4:29 pm ] |
And so it starts. ![]() |
Author: | CAJUN OUTLAW [ Wed Sep 07, 2011 4:35 pm ] |
robin,id have to say,you deserve all the sh!t you get on here.I'd be too embarassed to log on if i was you! ![]() |
Author: | Robn1020 [ Wed Sep 07, 2011 4:37 pm ] |
Author: | CAJUN OUTLAW [ Wed Sep 07, 2011 5:43 pm ] |
apology accepted,now go argue with ddm. |
Author: | MaXXis85 [ Thu Sep 08, 2011 8:29 am ] |
Yes the bearing housing is left handed threads. |
