It is currently Wed Sep 24, 2025 6:31 am
Reply to topic  [ 9 posts ]
 water in clutch housing.
Post water in clutch housing.
Pulled the bolt thats on the bottom of my motor tonight and when it came out it had about half a gallon of water in it , is this something i should be conserned about.Thanks
1542 stuck to a 27mini. She gone.
1746 with a modded 35 gdsd
Capt Team total asalt
Tue Aug 16, 2011 6:42 pm
Post Re: water in clutch housing.
Yep. Now you have to sell it.
Jus kiddin. My GTR gets water in the belt housing when it rains real hard. I just run it and dont worry about it. I dont know about a MB.
Tue Aug 16, 2011 6:51 pm
I don't think they supposed to get water in a mb
17x48 extreme stage 2 GTR
Tue Aug 16, 2011 6:55 pm
Ya I don't really know this is my first surface drive , switched from my longtail ,can't seem to find a place where it would come into the housing the bolt on the bottom was tight when I took it out.
Tue Aug 16, 2011 6:58 pm
Put yer face in the myrtles.
Tue Aug 16, 2011 7:12 pm
^^^What they said^^^ MB beltdrive is supposed to be sealed. Pull the clutch cover off & check the sealant between the clutch cover & the lower drive. Hopefully it's just leaking there, if not you gotta go further & pull the outdrive & check the seal on it.
This is all assuming that the vent on the front of the belt housing (port side) is facing down & not up.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Aug 16, 2011 8:02 pm
Assuming that you have a mini (from your signature), the mini frame has a plastic cover over the top 1/4 of the belt housing which isnt 100% water tight (just like a Gator Tail). Usually the belt picks up this water and slings it out, but it doesnt hurt to pull the drain plug and empty the water out manually either.
Oh and, cover your motor when in storage and it will stop this from happening.
Wed Aug 17, 2011 7:45 am
:oops: Missed the sig. Disregard my other post, I was referring to the Sport frame.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 17, 2011 11:43 am
Wed Aug 17, 2011 4:04 pm
