Average hours on prop?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=21464
Author:  WESTON [ Sat Aug 27, 2011 4:13 pm ]
Post subject:  Average hours on prop?
What is an average amount of hours yalls props last? I have only had my motor in mud a couple of times but can already see a ton of difference. I know that what u run in dictates the amount. Just looking for an average.
Author:  Woodiebuster [ Sat Aug 27, 2011 6:39 pm ]
Post subject:  Re: Average hours on prop?
Mudmotors, not sand motors.
You can burn a prop in just a couple of hours if you run onto a sandy bottom.
I run in water that is normally 1+ feet deep, my prop has 50 or so hours with no signs of wear.
Author:  wm [ Sat Aug 27, 2011 7:18 pm ]
my og prop was toast in less then 20 hrs running mostly sand new prop not seeing so much sand i cant afford a new prop every 20 hrs thats every week to week and a half for me :shock: :shock:
Author:  backwater86 [ Sat Aug 27, 2011 8:32 pm ]
Smoked up a prop just being to stubborn to get out of the boat and pushing off the sand bar last week
Author:  WESTON [ Sat Aug 27, 2011 8:47 pm ]
I have been in deep mud mostly. Deep enough to put the trim all the way down and gas on it. Some sand tho. Just wondering how many hours I should be getting.
Author:  LA Mudder [ Tue Aug 30, 2011 4:50 pm ]
what kinda motor u got cause a gt wheel will wear faster than a mb or pd wheel
Author:  MaXXis85 [ Wed Aug 31, 2011 6:40 am ]
135ish hours on my original GTR wheel. Never ran much sand, mostly mud and veggies. I have about .25" missing. It still runs decent in the deep but in the mud it isnt biting near as hard as a new prop did.. Once you lose the .25" its time for a prop.
Author:  WESTON [ Thu Sep 01, 2011 12:56 pm ]
It's my stock gt prop. Only 8 hrs on it. I haven't lost much speed but i can tell that it is smaller.
Author:  deltaduckmaster [ Thu Sep 01, 2011 1:02 pm ]
They can last years or minutes that all depends on you!!
Author:  Snowbird [ Thu Sep 01, 2011 6:16 pm ]
Author:  WESTON [ Fri Sep 09, 2011 6:53 am ]
Measured it this morning. It is 11" from end to end.
Author:  WestEndAngler [ Fri Sep 09, 2011 7:04 am ]
Author:  Gigafowl [ Fri Sep 09, 2011 7:08 am ]
Author:  WESTON [ Sat Sep 10, 2011 8:34 am ]
It is still running pretty good! Still pushes good and gets up pretty quick. May have lost a little speed but o well.
Author:  LA Mudder [ Sun Sep 11, 2011 7:36 pm ]
Author:  Beadlejuicejr [ Sun Sep 11, 2011 8:02 pm ]
Author:  LA Mudder [ Mon Sep 12, 2011 9:13 pm ]
Since ive never wore down each and every wheel i cant be absolutely sure but i believe the gt wheel is the thinnest of them all. what your sayin about the pd wheel is that once the cup alone is gone is aint worth a crap? my gt wheel almost comes stock with hardly any cup
Author:  Beadlejuicejr [ Mon Sep 12, 2011 9:19 pm ]
Its two totally DIFFERENT wheel designs
Author:  Beadlejuicejr [ Mon Sep 12, 2011 9:21 pm ]
Once that little stupid tip they put on the wheel loses the cup it has in it the wheel is junk you get it now or ou need a diminstration. Just cuz a prop is thinner doesn't mean nothin its all in the design
