HELLLLLLP!!!!!!!!!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=21881 |
Author: | UTgodevil23 [ Thu Sep 08, 2011 6:46 pm ] |
Post subject: | HELLLLLLP!!!!!!!!!! |
Author: | earl33 [ Thu Sep 08, 2011 7:28 pm ] |
They say Giga has some good GD lube. But I don't know for sure. |
Author: | UTgodevil23 [ Thu Sep 08, 2011 7:30 pm ] |
Post subject: | Re: HELLLLLLP!!!!!!!!!! |
Giga? |
Author: | POKER1 [ Thu Sep 08, 2011 7:30 pm ] |
Author: | UTgodevil23 [ Thu Sep 08, 2011 7:33 pm ] |
I seriously need to get this sucker off tomorrow before Saturday WOODY SEASON! |
Author: | earl33 [ Thu Sep 08, 2011 7:49 pm ] |
WD40 a block of wood and a dead blow hammer. Aw and make sure your beating the right way. |
Author: | bbb [ Thu Sep 08, 2011 9:02 pm ] |
You need to heat the hub of the prop with a torch, until it glows. It will torque off easily then. Or you can hold the set nut with a crescent wrench and hit the prop blade with a sledge hammer. I use a cinder block to set the skeg on top of so there is little movement of the shaft. Destroys the prop, but sometimes gets it off. |
Author: | lastchance [ Thu Sep 08, 2011 9:05 pm ] |
Author: | b_coonass [ Thu Sep 08, 2011 9:32 pm ] |
Author: | Snowbird [ Thu Sep 08, 2011 9:50 pm ] |
is it threaded? they sell prop wrenches at home depot... 2"x.25" flat bar with the appropriate size hole should work. spray the nut down with a penetrating lubricant like PB break first. |
Author: | bbb [ Fri Sep 09, 2011 5:59 am ] |
Author: | deltaduckmaster [ Fri Sep 09, 2011 7:56 am ] |
Wow !! It's taken less than minute to take one off and put back on!! Just saying !! |
Author: | bbb [ Fri Sep 09, 2011 11:46 am ] |
Author: | UTgodevil23 [ Wed Sep 14, 2011 5:41 am ] |
Thanks Guys for all the ideas. A little PB Blaster and an Eastwing finally did the trick ![]() |
Author: | bbb [ Wed Sep 14, 2011 8:08 pm ] |
It's a good feeling when it finally spins. |
