PD pipe plug http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=22289 |
Author: | Andrew22 [ Mon Sep 19, 2011 12:03 pm ] |
Post subject: | PD pipe plug |
Serviced my engine yesterday and changed the oil in the lower unit. Not only did it have some water in it but when I went to grease the lower unit fitting I saw I have no pipe plug. I am suppose to have one right? Is this how the water is getting in and how serious is it? |
Author: | POKER1 [ Mon Sep 19, 2011 12:49 pm ] |
Post subject: | Re: PD pipe plug |
Which plug you talking about? There is more than 1 but yes, every hole should have something in it............ ![]() |
Author: | Andrew22 [ Mon Sep 19, 2011 1:40 pm ] |
Page 15 of owners manual for short shank LU. Really not sure how long I've been running without it. Really hope I haven't screwed something up. |
Author: | POKER1 [ Mon Sep 19, 2011 6:26 pm ] |
You talking about the plug giving you access to the top shaft bearing zert? Take a pic. |
Author: | Pooh Bear [ Mon Sep 19, 2011 6:58 pm ] |
Do you have the new version L/U? If so,the plug you are talking about doesn't let water in. It only hides the grease zerk fitting. |
Author: | POKER1 [ Mon Sep 19, 2011 7:09 pm ] |
Author: | Andrew22 [ Tue Sep 20, 2011 7:20 am ] |
Author: | Ruddyduck [ Tue Sep 20, 2011 10:02 am ] |
If its a 2010 and you have water in the LU, take it in and have the seals replaced under warrantee. |
Author: | POKER1 [ Tue Sep 20, 2011 3:15 pm ] |
Author: | pooldoo73 [ Tue Sep 20, 2011 7:08 pm ] |
Water in the gear box is not OK by any means. Water has to travel a long way up the grease sealed prop shaft and then break through another set of seals to get in the gear box. U can tell when the lower prop shaft seals start to go out when u pump grease into the housing and u see water squeeze out before the grease. |
