It is currently Tue Sep 23, 2025 4:24 pm
Reply to topic  [ 10 posts ]
 PD pipe plug
Post PD pipe plug
Serviced my engine yesterday and changed the oil in the lower unit. Not only did it have some water in it but when I went to grease the lower unit fitting I saw I have no pipe plug. I am suppose to have one right? Is this how the water is getting in and how serious is it?
Mon Sep 19, 2011 12:03 pm
Post Re: PD pipe plug
Which plug you talking about? There is more than 1 but yes, every hole should have something in it............ :lol:
18x48 Charles Leonard / 36PD
Mon Sep 19, 2011 12:49 pm
Page 15 of owners manual for short shank LU. Really not sure how long I've been running without it. Really hope I haven't screwed something up.
Mon Sep 19, 2011 1:40 pm
You talking about the plug giving you access to the top shaft bearing zert? Take a pic.
Mon Sep 19, 2011 6:26 pm
Do you have the new version L/U? If so,the plug you are talking about doesn't let water in. It only hides the grease zerk fitting.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Mon Sep 19, 2011 6:58 pm
Mon Sep 19, 2011 7:09 pm
Tue Sep 20, 2011 7:20 am
If its a 2010 and you have water in the LU, take it in and have the seals replaced under warrantee.
Tue Sep 20, 2011 10:02 am
Tue Sep 20, 2011 3:15 pm
Water in the gear box is not OK by any means. Water has to travel a long way up the grease sealed prop shaft and then break through another set of seals to get in the gear box. U can tell when the lower prop shaft seals start to go out when u pump grease into the housing and u see water squeeze out before the grease.
18'x54"CC Hanko/ 36PD
Tue Sep 20, 2011 7:08 pm
