It is currently Wed Sep 24, 2025 9:57 am
Reply to topic  [ 33 posts ]
 PD Prop
Post PD Prop
Im replacing a worn out prop on my 36 PD. I have heads carb and exhuast. would you go with a stock PD or what???
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Sun Sep 25, 2011 6:17 pm
Post Re: PD Prop
I would like to know the same info.
Just installed my heads today and can easily hit rev limiter.
What options do we have.
Sun Sep 25, 2011 6:56 pm
Post Re: PD Prop
i like the hopkins
driving a gd in ur lake
and i aprove this message
Sun Sep 25, 2011 7:53 pm
Post Re: PD Prop
Which hopkins do you have? What mods?
Mon Sep 26, 2011 8:41 am
Post Re: PD Prop
I bought a Hopkins 12x14 cleaver. The prop is very smooth and has almost 0 vibration. Jumps up on plane and increased speed about 1mph while reducing RPMs by about 200-250. Lift the azz end and overall seems to run well. Havent run it in mud but it did seem the wrap up thick veg some where the PD doesnt. I still need to do some more running before I know for sure but the reduced rpms may play a part in that. I like it so far and if nothing else it will be a great fishing prop. Did I mention no vibration. Maybe there is something to this balancing thing.............
18x48 Charles Leonard / 36PD
Mon Sep 26, 2011 1:25 pm
Post Re: PD Prop
yep poker had to move the trolling batt back because of the lift but it REALLY DIGGS in the mud , short i haver the stock what everone calls the cleaver 12x 13 no mods , but after duck season i am im heads , gonna add a 1/2 or 1" to the picth he is coming out with another prop i heard
Mon Sep 26, 2011 2:44 pm
Post PD Prop
I sent him a 12x14 to be re worked and he said no problem when he got it. I got it back and it ran a whopping 22 mph at 4300 rpm...haven't contacted him about it yet.
Mon Sep 26, 2011 3:01 pm
Post Re: PD Prop
***** will make it right
Mon Sep 26, 2011 7:37 pm
Post Re: PD Prop
These props are hard for someone to get right the first time!When I was running the prodrives I tried and tested alot of props for Hopkins.On a stock prodrive his 13 inch with a light cup!One thing is that he will get it right for you!!Good Luck
Mon Sep 26, 2011 8:11 pm
Post Re: PD Prop
i am needing a prop for my stock pd 36hp.. what do you reccomend?
17x54 prodrive x series powered by 36hp prodrive..
Prodrive prostaffer
Timber ridge retriever
Mon Sep 26, 2011 8:17 pm
Post Re: PD Prop
So considering the mods I have, IM heads, Mikuni Carb, BPS Exhaust and prob an EVT cam to come, what would you go with? the 12X13 or 12X14?
Tue Sep 27, 2011 7:59 am
Post Re: PD Prop
Call hopkins he will help ya
And I drive a pd and approve this message
Tue Sep 27, 2011 8:05 am
Post Re: PD Prop
It takes a lot of power to turn his 14 Cleaver!RC was running a 14 and his motor had all the goodies in it.It all depends on the cup and tip curl also,Like others said,Give Hopkins a call and get started!Good Luck
Tue Sep 27, 2011 4:51 pm
Post Re: PD Prop
Tue Sep 27, 2011 4:53 pm
Post Re: PD Prop
well hell, I ordered the 14 today. Maybe I should call him back and get the 13. He said that if I put a cam in my motor like im kinda planning on, the 13 prob wouldnt be enough. So we decided to go with the 14 with my current mods and if its not enough, put a cam in it and that should be enough. What do you guys think?
Tue Sep 27, 2011 9:10 pm
Post Re: PD Prop
I can turn that 12x14 at 4100 with those mods.
Tue Sep 27, 2011 9:15 pm
Post Re: PD Prop
12x13 ican turn 4200 on my cdi with exshast
Tue Sep 27, 2011 9:30 pm
Post Re: PD Prop
Like I said,It depends on how much cup he puts in them!The ones that I was running had different amount of cup.Try the one he is sending you and call him with results!You might have to send it back a couple times but you will be right when it is done ;)
Wed Sep 28, 2011 5:37 am
Post Re: PD Prop
Good deal, thanks guys for all the info and thanks other guys for not chiming in with BS to aggitate other people. I think this is my first post that has ever stayed on point.
Wed Sep 28, 2011 7:46 am
Post Re: PD Prop
FYI....
There is a theory out that a prop can be a deciding factor in cracking your block due to keeping your motor at peak torque at all times. We all know the blocks are weaker than what we need for heavy mods. So if the motor is a 100% torque with lots of load (caused by prop) than its plausible.
I had a 12x14 light tip curl on a stage 1 and it ran 33 with no problems. I had a 12x14 heavy tip curl and it would not turn over 3800 and the block split right down the middle. I passed the prop on to the next guy (way before anyone had thought the prop could be the problem) and I don’t know what happed to his motor but it’s not running any longer. Adam what happened to your motor.
If you cannot turn the prop over 4100 RPM get some tip curl taking out of it.
Don’t know who posted the theory first, but I have thought about it for a long time now. It might have been Mike, but I’m not giving him credit for crap :lol: :lol: :lol: LMAO. If anyone else has researched/thought about the props being a potion of the problem but that what I’m thinking.
Thu Oct 06, 2011 6:24 am
Post Re: PD Prop
Mike has posted many times. If you prop your motor so much to lower rpm's while still keeping the motor at Full throttle, all you are doin is making the engine work harder. Lessen the pitch or cup to make your engine run efficient so you dont have to have that sucker lugging and working hard just to spin a prop. Can you imagine too much prop and a heavy load? that motor will just come apart.. So there is the thing called a throttle.... use your had to control the speed of the engine. Lugging is not the bestr way to control RPM's
Thu Oct 06, 2011 6:45 am
Post Re: PD Prop
After grinding that 12x14 heavy tip some today I have concluded it is too much for my setup when in the thick stuff. Works great for open water and I run alot of that fishing so I think I'll keep it like it is but will go back to the PD prop for the grinding time. May take some tip off of it. Just can't spin it up right when in the thick veg and mud. Once it gets the rpms up its a hoss but getting it up there consistantly will take more than heads, carb and exhaust. And its does seem to be putting the motor in more of a bind trying to keep them up there with some resistance from veggies so that cant be good for the long haul.
Fri Oct 07, 2011 8:58 pm
Post Re: PD Prop
I got a 12x13 from Hopkins wif heavy curl and cup. Heads, carb, and exhaust. A get my best speed at 4200. I can turn it to the limiter, but lose speed as I trim it more. My prop likes to run deeper than the PD prop. No way I could turn a 12x14 built like this one.
18'x54"CC Hanko/ 36PD
Sun Oct 09, 2011 2:01 pm
Post Re: PD Prop
Well Ive already ordered it now. HAHAHA I guess Ill give it a try and if need be, have them take some curl off of it. Thanks for all the great info.
Mon Oct 10, 2011 10:14 am
Post Re: PD Prop
Well I ran the new prop. Im not getting all the RPMs I need. I just moved my Tach and had to extend the wire, Im not positive its reading exactly right. it seems to be updating slower than before. But If its reading correctly, Im getting around 3400 RPMs. I am still running 28 with two people. Hopefully my EVT cam will be in soon. If Im actually turning 3400 now, and I get 4200 with the upcoming mods, its gonna fly!
Sun Oct 16, 2011 10:16 am
Post Re: PD Prop
i have a stock pd... i just ordered a 12x12 hopkins cleaver prop... how do you think it will do with 1754 flat bottom boat? what kind of sppeds and rpms will i ge?t you think? i had a prodrive prop that was slap wore out.. 2in shorter than it was brand new and even has a chunk taking out of it... i got 20-24mph turning 4050-4090 rpms
Prodrive prostaffer
Wed Oct 19, 2011 3:11 pm
Post Re: PD Prop
Wed Oct 19, 2011 4:15 pm
Post Re: PD Prop
Cam isn't even gonna make enough difference to get your revs up high enough if u can only turn it 3400 now.
Wed Oct 19, 2011 6:04 pm
Post Re: PD Prop
Thu Oct 20, 2011 8:05 am
Post Re: PD Prop
If not, u can send it back and get some cup/curl removed and u will b good to go.
Thu Oct 20, 2011 2:23 pm
Post Re: PD Prop
Yeah thats the plan. My cam should be here today. Ill get er in and see what weve got. If its not enough Im sure hopkins will get it right.
Fri Oct 21, 2011 8:45 am
Post Re: PD Prop
Got my cam in last night. Ill go run it today and see how she does. Yall keep your fingers crossed! Ill report back and let you know.
Tue Oct 25, 2011 10:20 am
Post Re: PD Prop
well,,,whats the verdict? hopkins or stock?
Wed Jun 13, 2012 11:50 am
