It is currently Tue Sep 23, 2025 10:18 am
Reply to topic  [ 6 posts ]
 Something Different
Post Something Different
I had seen a surface drive today, it was a 29HP vanguard. It had a longer lower unit than normal. I was wondering if anyone knew what this type of surface drive is called? and if they are any good?
Sun Oct 02, 2011 1:26 am
You probably saw an older mudbuddy from around 2004-2006.
Back then the drives were longer and then they started getting shorter and shorter.
They stopped using the 29's a while back.
Sun Oct 02, 2011 6:41 am
Post Re: Something Different
Sounds like one of the old balanced hypers.
Sun Oct 02, 2011 11:54 am
Old hyper, my buddy has one. Got it back when they first came out.
Sun Oct 02, 2011 11:56 am
Ever heard anything bad about these motors?
Tue Oct 04, 2011 6:20 pm
The power head is basically a 35.
Shorter stroke, smaller carb, different cams and stuff.
The frame is what it is...
Tue Oct 04, 2011 6:39 pm
