worn down prop
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=23077
Author:  torrey w [ Thu Oct 13, 2011 8:49 pm ]
Post subject:  worn down prop
How bad could a worn down prop effect speed? I have a 2007 MB 23 mini. And after running the river of course finding a few sand bars hard i noticed on the lake that im only running around 10 mph vs the 21 mph with about the same loads. 2 guys 2 dozen dekes and other small gear in a 1648 alumacraft jon. Or do i have something else going on.
Thanks
Torrey
Author:  POKER1 [ Thu Oct 13, 2011 8:52 pm ]
Post subject:  Re: worn down prop
My guess is you found out for yourself. Aside from the engine actually running it has everything to do with speed. :lol: Sand+props=Devil. :lol:
Author:  BoatDR [ Thu Oct 13, 2011 8:52 pm ]
Author:  torrey w [ Thu Oct 13, 2011 9:01 pm ]
Rpms seem to be aboat the same but from what i read they are a little higher then most at 4100 in water and the over all length is 9.5 inches and one blade is like 5 inches or little under wide. Just wanted to make sure before i tried to order one. Any suggestions on what i should get and best place to order from not sure if there is a dealer near me
Thankd
Author:  BoatDR [ Thu Oct 13, 2011 9:04 pm ]
MB only offers 1 prop for the mini, an 11x10. However you need to remove it and see if you have a hex or threaded shaft.
And where are you?
Author:  torrey w [ Thu Oct 13, 2011 9:05 pm ]
Mankato, mn
Author:  BoatDR [ Thu Oct 13, 2011 9:11 pm ]
You'd have to call MB to find out who is the closest.
The only dealer I know of in that region is in Lacrosse. If you want his info pm me.
Author:  torrey w [ Thu Oct 13, 2011 9:38 pm ]
Thanks i will try to call mudd buddy agaun tomorrow tried today
Author:  Mag10 [ Fri Oct 14, 2011 12:06 pm ]
Order it straight from Mud Buddy. It will be easier than trying to find someone around So. Mn.
Sent you a PM
Mag10
Author:  ironman_gq [ Mon Oct 17, 2011 12:03 pm ]
I think Backwater is in MN, they make props and motors, might be able to help you out
