It is currently Tue Sep 23, 2025 11:38 pm
Reply to topic  [ 3 posts ]
 Transom height GDSD
Post Re: Transom height GDSD
Mount it and run it for awhile and see if it will work for you. If not then cut it down. Just my opinion. Duckdon
Tue Nov 01, 2011 9:14 pm
Just to be clear - 17' means 17 feet & 17" means 17 inches....
So your hull has a 17 inch transom height ?
In a PM - I asked you - if your hull were level then you adjusted your GDSD till
the lower fins were level - then looked from the rear down those lower fins back toward
the transom - where are they aligned in regard to the transom and hull bottom ???
Eat - Sleep - Hunt ! ! !
Tue Nov 01, 2011 9:32 pm
1" only matters with diks and props.
Run it like it is before you risk messing it up.
Tue Nov 01, 2011 9:36 pm
