PD 36 lower unit leak http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=23386 |
Author: | banded-mallard [ Mon Oct 24, 2011 12:53 pm ] |
Post subject: | PD 36 lower unit leak |
Came back from a ride today and noticed this, Also had some burp out the vent under the clutch that was milky. Any ideas? Normal riding, open water. |
Author: | JIMMY W [ Mon Oct 24, 2011 4:24 pm ] |
Post subject: | Re: PD 36 lower unit leak |
Search that topic,That has been a problem on the prodrives!One of the seals are more than likely bad,Just have to figure out which one!Give Peck a shout at Prodrive. |
Author: | XGEN-DUCKMAN [ Wed Oct 26, 2011 12:23 am ] |
Check for a case gasket leak, a little oil can make a big mess on that plate ends up all over the one side. |
Author: | JIMMY W [ Wed Oct 26, 2011 6:28 am ] |
Author: | UNCLE-J [ Wed Oct 26, 2011 7:51 am ] |
It is your bottom seal. Directions: Order a new Nut and seals from PD(seals are in nut) Take prop nut off Take prop off Take nut off (behind prop) Put new nut on with new seals Put prop back on Put prop nut back on DONE |
Author: | banded-mallard [ Sun Oct 30, 2011 1:24 pm ] |
Been working but talked to KP. I have the old style seal nut. Need to swap out to new nut and seals and give it a try. |
Author: | T-Bubba [ Sun Oct 30, 2011 5:00 pm ] |
is that a old style lower unit? I just had to change my seals after 185hrs |
Author: | bayouboy [ Sun Oct 30, 2011 6:24 pm ] |
Author: | UNCLE-J [ Sun Oct 30, 2011 6:32 pm ] |
O yeah... That's important.. |
Author: | banded-mallard [ Mon Oct 31, 2011 2:25 pm ] |
Author: | POKER1 [ Mon Oct 31, 2011 6:53 pm ] |
