It is currently Wed Sep 24, 2025 9:28 am
Reply to topic  [ 14 posts ]
 Shaft Angle?
Post Shaft Angle?
I am fairly new to the Mud Motor world even though I've had a small go-devil since I could drive. I recently got a 2007 MB sport and I'm having a lot of trouble getting it to plane in thick vegetation. It is on a 17/54 and is a 35hp stock but has several mods done and is supposed to be putting out around 45hp?
Anyway, in open water it flies. But is not impressive in mud or thick vegetation? It is on Xpress new mud boat, I am wondering if it is getting trimmed low enough under the boat to get a good push??
Thanks
Aux Arc
Mon Oct 17, 2011 8:54 pm
Post Re: Shaft Angle?
Are you running a short transom motor on a tall transom boat
Mon Oct 17, 2011 8:57 pm
SHORT, BUT I FEEL LIKE THE TRIM ISNT GETTING LOW ENOUGH LIKE I SEE ON YOUTUBE?
THANKS
AUX ARC
Mon Oct 17, 2011 9:18 pm
Idk the transom angle suggested for MB but I would see if the transom an motor angles match.
Mon Oct 17, 2011 9:22 pm
Post Shaft Angle?
Should be 20* for the MB I believe
Mon Oct 17, 2011 9:24 pm
A pic or two might help you get some input from the MB guys...
Maybe a side shot - trimmed down - with the camera down even with the hull bottom...
Some combos can benefit from a wedge between motor and hull to get the trim right
maybe someone will pick up on something that can help you....
A blind - dumbazz guess could be prop wear - a worn prop will loose azz in the muck
but still turn up pretty good speed at WOT... What rpm you turning ???
Eat - Sleep - Hunt ! ! !
Mon Oct 17, 2011 9:28 pm
Pretty sure those boats are built for a GTR so the angle will be about the same.
Mon Oct 17, 2011 9:32 pm
Thanks a bunch. I'll try and get picks asap.. I run around 4000 rpm
I think a shim would prob help alot
Tue Oct 18, 2011 9:40 am
Tue Oct 18, 2011 10:56 am
I run a 3man hide with a 45mag, they say the longer drives help get the bigger/wider boats own plane faster with a load in them. So the 27in drive ain't getting a bite that a 32/40in drives do to get u going. Gona get a 40in in a month or so and find out for my self.
Prodigy 1851 elite timber , 4400 HDR .
Tue Oct 18, 2011 11:21 am
[quote="g-devil"]I run a 3man hide with a 45mag, they say the longer drives help get the bigger/wider boats own plane faster with a load in them. So the 27in drive ain't getting a bite that a 32/40in drives do to get u going. Gona get a 40in in a month or so and find out for my self.[/quote]
i would ask around first. i have heard that some people didn't like them. Not positive just thought i read it somewhere.
Tue Oct 18, 2011 3:43 pm
yea they don't like the tiller torque, but when u go from running a 35lt these surface drives aint got any. lol
Tue Oct 18, 2011 4:06 pm
hahahahaha i hear that
Tue Oct 18, 2011 4:08 pm
I lowered my transom, it helped some. I am also coming to grips with the fact that I am in suuuuper thick vegetation. Nothing can plane you fast in this stuff!!!!!
Thanks
AUX ARC
Wed Oct 26, 2011 8:15 pm
