Transom height GDSD http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=23616 |
Author: | Duckdon [ Tue Nov 01, 2011 9:14 pm ] |
Post subject: | Re: Transom height GDSD |
Mount it and run it for awhile and see if it will work for you. If not then cut it down. Just my opinion. Duckdon |
Author: | Gigafowl [ Tue Nov 01, 2011 9:32 pm ] |
Just to be clear - 17' means 17 feet & 17" means 17 inches.... So your hull has a 17 inch transom height ? In a PM - I asked you - if your hull were level then you adjusted your GDSD till the lower fins were level - then looked from the rear down those lower fins back toward the transom - where are they aligned in regard to the transom and hull bottom ??? |
Author: | Woodiebuster [ Tue Nov 01, 2011 9:36 pm ] |
1" only matters with diks and props. Run it like it is before you risk messing it up. |
