It is currently Tue Feb 19, 2019 5:35 pm
Reply to topic  [ 16 posts ]
 Bending the skeg on Mudbuddy?????
Post Bending the skeg on Mudbuddy?????
I'm tired of the tiller tourque from my mudbuddy. The skeg is already bent from the factory. What's the best way to bend it a little more. Should it be heated a little or just muscled over with a large crescent wrench? Anybody else done this?
18x44 Gator Trax, Stage 2 Mudbuddy
Wed Nov 16, 2011 2:58 pm
Post Re: Bending the skeg on Mudbuddy?????
I use a large pipe wrench with a long pipe. I put a rag on the skeg and put the wrench on it.
Sent from my ADR6350 using Tapatalk
Wed Nov 16, 2011 3:29 pm
befor you go bending the skeg. Have your tried position weight differently in the boat? (with out if affecting your speed)
Gave up hunting ducks and started underwater basket weaving!
Wed Nov 16, 2011 3:31 pm
Grab a wrench and go to town. They're not always bent enough
Wed Nov 16, 2011 3:46 pm
Distributing your weight evenly will help out alot!!!!
SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon
GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Wed Nov 16, 2011 4:11 pm
Trim down a little bit. Find that sweet spot and the the tiller torque is minimal.
What motor do you have??
A 18x20 hollowed out log and a long stick
crazybrady wrote:
next time you come across my pond like that I’m eatin your lunch!
indawoods wrote:
reach down on the floor, pick up your brain, and put it back in your head.
If Obama had a city it would look like Detroit.
Thu Nov 17, 2011 8:31 am
I have a 70lbs battery in front on the left and 6 gallon fuel tank on the right. 50lb battery inback on left. It's the same with both batteries in the rear. Adding my 200 lbs son does change anything either. If he sits in front on the deck or just a little in front of me. I have to make a little ajustment and see how it goes. Thanks for the input.
Thu Nov 17, 2011 12:21 pm
[quote="Goose Crumpler"]Trim down a little bit. Find that sweet spot and the the tiller torque is minimal.
I'm running a mudbuddy 35
Thu Nov 17, 2011 12:24 pm
Hey guys I got it working good now. I used a pipe wrench and cheeta pipe. I bent the skeg another inch and it works perfectly. No torque problem. Almost stays centered on it's own. Much easier on my arm. Thanks for the advice.
Thu Nov 17, 2011 6:15 pm
I would have recommended mounting the motor about 1" off center toward the starboard and adjusting it from there. This has been the most effective way of eliminating tiller torque for me. Bending the skeg is the last option to take, it weakens the metal and can come out of adjustment when you strike objects at speed.
Sun Dec 04, 2011 10:00 am
you know i read that when i mounted my motor. i called kevin and he said it didnt matter that much. i think i offset it anyway. with a smaller boat it seems to help more than a bigger boat.
Mon Dec 05, 2011 8:30 pm
Well bending it did work perfectly. I bent it at the correct spot. Not the tip of the skeg. I'll just have to see if it holds up now. I'm not sure what he considers a big boat. Mine is 18x44. Not very wide, but it is long.
Wed Dec 07, 2011 12:05 am
i was talking about the off set motor. yes bending it more does work. i had to bend mine some.
Wed Dec 07, 2011 4:07 pm
I know you were talking about off setting the motor, but I was wondering what the other guy considered to be a big boat as to offsetting the motor not helping.
Wed Dec 07, 2011 6:52 pm
Ill be bending mine this weekend. When full throttle the hdr tillrr handle wants to move starboard. Thinking more bend of the skeg port side should help.
Tue Jun 05, 2018 7:22 pm
My skeg was bent about prefect from factory. I have had the bolts loosen from vibration and it causes really bad tiller torque. Make sure those bolts are tight, lock tight isn't a bad idea either, before you bend it. If you do bend it, it shouldn't take much bend so don't get crazy, do a little bit at a time until you get it how you like it.
Wed Jun 06, 2018 8:43 am
Users browsing this forum: rbeck and 9 guests
