It is currently Wed Sep 24, 2025 9:30 am
Reply to topic  [ 5 posts ]
 2009 PD 27 hp, gear problem
Post 2009 PD 27 hp, gear problem
Fellas I purchased my first MM this summer. It has manual reverse. Everything has been working great til this past weekend I switched the lower unit to reverse to set decoys in deep water. Not sure if I didn't get it locked back in to forward but when I pulll the red button out for constant power nothing happens. I can push the black button for temporary power and it works fine. I have tried to rotate the lower unit around and make sure it's locked in but still no power. Any suggestions??? Lynn
Mon Nov 28, 2011 9:18 pm
Post Re: 2009 PD 27 hp, gear problem
Your switch might be broke or the connections on the back came loose.
Mon Nov 28, 2011 11:48 pm
bad clutch switch,
first clutch switch (red button) goes, then when your limping in momentary goes (black one) if not clutch usually suffers death lol, you do not have to have the lower unit ratcheted fully around to put it in gear, you never heard of fpsw! full power side ways!. I think the clutch switch is 40 bucks.
27 Contender twin 200's
for sale
Tue Nov 29, 2011 1:26 am
Tue Nov 29, 2011 9:55 am
x3 and the position of the LU has nothing to do with clutch engagement. I run mine sideways sometimes to spin the azz end around.
18x48 Charles Leonard / 36PD
Tue Nov 29, 2011 6:49 pm
