This doesn't look good http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=24208 |
Author: | SSPhone [ Sun Nov 20, 2011 5:50 pm ] |
Post subject: | This doesn't look good |
What a day. 88* sunny and hot. See all total of about 20 ducks and ended up with 3 out of 5 shots. So decided to scout a bit on the way back in. Heard a thump and then smell 90 W gear oil. Look back and find MILK ![]() |
Author: | duckduckboom [ Sun Nov 20, 2011 5:52 pm ] |
Post subject: | Re: This doesn't look good |
drain lu oil remove prop remove seal nut replace with new seal nut reinstall prop add gear oil run it like you stole it |
Author: | cb5331 [ Sun Nov 20, 2011 5:56 pm ] |
"heard a thunk"? Did the case split? Gears lock up? Still running or what? |
Author: | naj [ Sun Nov 20, 2011 6:08 pm ] |
I have never seen oil hat white. Where did it come from. |
Author: | POKER1 [ Sun Nov 20, 2011 6:10 pm ] |
Author: | SSPhone [ Sun Nov 20, 2011 6:20 pm ] |
The lower seal was replaced with the new 3 seal nut about 6 weeks ago. Ran the motor with new 90W and drained it again refilled again with new 90W. This all came out of the top behind the cover for the clutch. Oh and it didn't lock up. Eased it back to the ramp and onto the trailer. |
Author: | banded-mallard [ Sun Nov 20, 2011 8:30 pm ] |
thats what just happened to mine. Lower seals went out, sucked in water, built up pressure and blew it out the vent which is by the clutch. Replace seals. |
Author: | POKER1 [ Sun Nov 20, 2011 8:33 pm ] |
Author: | bayouboy [ Sun Nov 20, 2011 8:36 pm ] |
You should have bought a tall transom! You could have gotten at least 2 more hunts out of it! ![]() Hate to say it, but you might have a worn prop shaft ( look for grooves where the seals ride the shaft). The plus side is you can upgrade to the newer grease filled LU! Its the schitt! |
Author: | duckduckboom [ Sun Nov 20, 2011 8:39 pm ] |
mine looks like the right now because i sucks some avery fast grass up. shit bogged my motor down. 30 minutes to cut it out |
Author: | SSPhone [ Mon Nov 21, 2011 7:22 pm ] |
Author: | SSPhone [ Wed Nov 30, 2011 9:07 am ] |
Got the seal nut in yesterday and installed it last night. Filled with 90W and we're ready to go again. |
Author: | take'emgator [ Wed Nov 30, 2011 11:49 am ] |
Glad you back on the water, thankfully it was a fairly easy fix |
