2007 Prodrive lower unit problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=24342 |
Author: | Landry18 [ Thu Nov 24, 2011 10:01 pm ] |
Post subject: | 2007 Prodrive lower unit problem |
I just bought a 2007 32 prodrive. The motor runs great but i have what appears to be a oil/grease leak at the top of the lower unit right underneath the top skeg plat bracket. Does anyone one know how to address the problem. I spoke to a friend who is a mechanic who said to change the seals. I am just worried that i just purchased one with the bad lower unit which prodrive discontinued. Please Help Here is a pic |
Author: | Landry18 [ Thu Nov 24, 2011 10:02 pm ] |
Post subject: | Re: 2007 Prodrive lower unit problem |
How much does a new lower unit cost from PD |
Author: | naj [ Thu Nov 24, 2011 10:06 pm ] |
Used to be able to trade in your old one with 600 buck and get a new one. |
Author: | Landry18 [ Thu Nov 24, 2011 10:09 pm ] |
Can i continue to run with this or its a need to fix asap problem? |
Author: | duckduckboom [ Thu Nov 24, 2011 10:15 pm ] |
Is it gear oil? |
Author: | Landry18 [ Thu Nov 24, 2011 10:17 pm ] |
not sure, how to check? Just bought it yesterday |
Author: | duckduckboom [ Thu Nov 24, 2011 10:21 pm ] |
The smell is a 100% dead give away |
Author: | Landry18 [ Thu Nov 24, 2011 10:23 pm ] |
Which would be? |
Author: | duckduckboom [ Thu Nov 24, 2011 10:28 pm ] |
Burnt popcorn and cunt hair. Idk man gear oil has a unique smell. Drain it and see if you have water in your Lu |
Author: | Landry18 [ Thu Nov 24, 2011 11:01 pm ] |
I checked the LU oil it is very cloudy like, white |
Author: | duckduckboom [ Thu Nov 24, 2011 11:04 pm ] |
If you ran it today it will be milky. Let it sit for a day then check it again |
Author: | POKER1 [ Thu Nov 24, 2011 11:20 pm ] |
You don't need a new LU. A seal change is in order and easy to do. Change the LU lube and run it. You will be fine till you get your lower seal from PD. I suggest getting a prop wrench and clutch pin (locks clutch to remove prop) while your at it. |
Author: | POKER1 [ Thu Nov 24, 2011 11:21 pm ] |
Author: | banded-mallard [ Fri Nov 25, 2011 11:29 am ] |
Author: | Landry18 [ Fri Nov 25, 2011 3:05 pm ] |
On a huntch i filled the grease fittings with grease and watched all the old grease and water roll out. I kept pumping until i seen new grease. 8 hours later the leak never returned. I think it was just old brokedown grease coming out. Since it never smelled like LU oil i think i fixed the problem |
Author: | JIMMY W [ Fri Nov 25, 2011 3:32 pm ] |
Get some seals and a prop wrench,You will need them!!It is nice to have an extra seal and prop on hand ![]() |
Author: | POKER1 [ Fri Nov 25, 2011 5:09 pm ] |
Grease does not run. I change my LU gear lube often so I dont worry about what it looks like. You will be fine. |
