It is currently Wed Jul 09, 2025 11:29 am
Reply to topic  [ 12 posts ]
 does this prop look wore out to you??
Post does this prop look wore out to you??
It's a 11x10 on a 29 HP mudbuddy
It only measures about 3/16 under but the Dang thing spins out bad on take off
Top speed is great just no bite on taking off
Sun Dec 18, 2011 11:24 am
Post Re: does this prop look wore out to you??
Really no one has.chimed in on this
Sun Dec 18, 2011 4:53 pm
If top end is still good prop is good unless you just wanna drop 250 on a new one
Sent via telegraph
Sun Dec 18, 2011 5:06 pm
Btw muffbuddy should be able to tell you after how many inches of decrease you need to change the prop.
Sent via telegraph
Sun Dec 18, 2011 5:07 pm
i see you have 22 posts. i know it doesnt show you time around these motors, but how long have you been useing a surface drive? not being smart just want to know if maybe you dont know exactly how they work.
it maybe that your are saying it " spins out" or cavatates as it it surfaceing. if so thats normal. stock the motor will pull very hard and lug down as you get on it from a stop. as you start moving and the rpm's climb and the boat starts to plane. at about that point the prop should start to surface and begin to cavatate. the r's will climb rapidly as should the speed and the boat should plane all at about the same time.
the reason i say this is you advised it runs out on top fine. maybe this is not the case. or maybe the boats loaded improperly, or trimed to high to start or its the wrong boat for the motor or or or .....
Mon Dec 19, 2011 9:56 am
I have just bought this motor I have had a long tail for about 12 yrs
Do yes I'm new to a SD
The rpms just right up to max rpms from.take off it really doesn't matter where I have it trimmed wheter its all the down or anywhere inbetween it just doesn't seem to have the take off i was expecting
But it could be my fat ass slowing it down also!!
Mon Dec 19, 2011 10:13 am
Mon Dec 19, 2011 11:00 am
youd have to measure the prop and know what it started out as to know for sure. but as of lookin at it it looks as though it has quite a bit of cup left to it.
Wish in one hand and shit in the other, see which one gets filled first.
If yur gonna be stupid, you might as well be smart about it.
Mon Dec 19, 2011 12:45 pm
If my prop wears just a little bit I lose a lot of hole shot.
17x50hd gator trax 45mag mb
Wed Dec 21, 2011 6:12 pm
1848 Prodigy
35 GTR
Fri Dec 23, 2011 7:16 pm
Fri Dec 23, 2011 8:10 pm
It's wored out get a new one.....,
Sat Dec 24, 2011 12:23 am
Users browsing this forum: Google [Bot] and 46 guests
