PD 36 auto reverse problems
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=25695
Author:  Booyah21 [ Wed Jan 11, 2012 8:43 pm ]
Post subject:  PD 36 auto reverse problems
I have a PD 36 auto reverse on a center console PD boat. I am having problem with my reverse. Sometimes, but not always, when I press the reverse button the lower unit rotates ridiculously slow and then stops, but you can hear the hydraulic pumps working. Then when it stops you can press the forward button and it goes back to forward with no problem but then press the reverse and it's slow again. Fluids are all good. Anyone else had this problem?
Author:  tchauvin [ Wed Jan 11, 2012 8:46 pm ]
Post subject:  Re: PD 36 auto reverse problems
hey pal,,,
i have had the same problem, i spoke to my dealer and he sais it cuased by a leaking reverse cylinder they claim they have seen this problem before and fix it with a cylinder swap. make since to me...
Author:  Booyah21 [ Wed Jan 11, 2012 8:57 pm ]
My rig is only 3 months old and I planned on bringing it back to the dealer, but it's gonna have to wait til after the season. I was hoping that it was nothing major. Thanks for your input
Author:  POKER1 [ Wed Jan 11, 2012 8:58 pm ]
Author:  Booyah21 [ Wed Jan 11, 2012 9:12 pm ]
Yes. All of the fluids are good and I have no leaks
Author:  johnny rebel [ Wed Jan 11, 2012 9:29 pm ]
Had the same issue with mine 2010 model. Kp said it was a warped cylinder barrel. Mine was doing what you described. Just remember you will have an issue in thick mud and will have to trim up to get in reverse. Call pd they'll fix it takes about ten minutes
Author:  Truckman [ Sat Jan 21, 2012 7:56 pm ]
Had the same issue an a new cylinder fixed it. Peck had me send mine in and he would repair or replace it.
Author:  flatboat [ Mon Jan 23, 2012 7:51 am ]
Call Peck and he'll get u a new I'm on my third one. The first 2 only lasted days but i've had the one I got now for the whole second split with no problems. It takes about 10 min. to swap em out.
Author:  bayouboy [ Thu Jan 26, 2012 10:31 am ]
It's more than likely you cylinder, but also if you over grease the reverse gears it allows a great place for everything to stick to, like mud, shells, small rocks etc....... All this can reak havoc on you gear lash causing it to bind.
