It is currently Tue Sep 23, 2025 7:33 pm
Reply to topic  [ 4 posts ]
 Bad grease fitting?
Post Bad grease fitting?
Mudbuddy 35 LA Special is pushing grease out of the shaft grease fitting (located on top of the shaft housing near the prop). im guessing the fitting has gone bad and all i need to do is replace it. thoughts?
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Tue Jan 17, 2012 8:10 am
Post Re: Bad grease fitting?
If the grease is coming out of the center the zert is bad, you can buy one at your local autozone or lawnmower shop!
Tue Jan 17, 2012 9:10 am
yeh its coming out of the center. didnt think it was anything more than a bad fitting, but wanted to make sure.
Tue Jan 17, 2012 9:15 am
Yea all there is is a ballbearing and spring when they wear out the ball falls out!
Tue Jan 17, 2012 9:17 am
