Which motor should I go after? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=25877 |
Author: | engineered34 [ Wed Jan 18, 2012 7:50 am ] |
Post subject: | Which motor should I go after? |
I am a new member here. I live in Roswell, GA only a few miles from the Chattahoochie River. I grew up in Alabama fishing big water Lakes like Jordan, and Martin and I don't have much experience with Mud Motors, or Jet Drives. As many of you know the Chattahoochie is extremely rocky and can be as shallow as a few inches depending on when they are pulling water from Lake Lanier. I am working on buying / building a pretty simple rig to get out on the Chattahoochie this Spring and Summer. My plan is to buy a used Jon Boat between 12' and 16' with trailer and mount some type of outboard that I can run up into extremely shallow water. I am looking for the CHEAPEST option possible. I am working on a shoestring budget so I'm sure everything I will be looking at will be used or a fixer-upper. Any advice you guys could give me on what type of motor to look for would be greatly |
Author: | Ruddyduck [ Wed Jan 18, 2012 8:33 am ] |
Post subject: | Re: Which motor should I go after? |
If you are only running a rocky, shallow river I think a LT would suit your needs. Check out mudbuddy, godevil, backwater. |
Author: | engineered34 [ Wed Jan 18, 2012 9:02 am ] |
Thanks for the tip. Is there any site I should check for used products? |
Author: | GSUrugger [ Wed Jan 18, 2012 9:04 am ] |
Author: | engineered34 [ Wed Jan 18, 2012 9:07 am ] |
Thanks!!! |
Author: | deltaduckmaster [ Wed Jan 18, 2012 9:15 am ] |
Sounds like you need a jet drive outboard!! |
Author: | GSUrugger [ Wed Jan 18, 2012 9:16 am ] |
Author: | Barroll [ Wed Jan 18, 2012 11:23 am ] |
check out my post on the engines forum. I am very familiar with that river. Ive run outboards, surface drives, and longtails on it... |
